[Geoserver-users] impossible to save configuration of feature type !
hi again,
i try to save my configuration (apply).
But geoserver seems to not give the right BBox parameters to jts...
i have postgis datastore, an empty table that i want to expose with one geometry field.
i first create new feature : ok
i fill the envelop (bbox) (needed to change the schema).
i change some field.
and i try to save (apply) my new settings :
then i've got this exception.
knonw bug ?
2007-10-15 15:13:51.102::WARN: /geoserver/admin/saveToGeoServer.do
java.lang.NullPointerException
        at com.vividsolutions.jts.geom.Envelope.init(Envelope.java:254)
        at com.vividsolutions.jts.geom.Envelope.<init>(Envelope.java:186)
        at org.vfny.geoserver.global.dto.CloneLibrary.clone(CloneLibrary.java:140)
        at org.vfny.geoserver.config.FeatureTypeConfig.toDTO(FeatureTypeConfig.java:354)
        at org.vfny.geoserver.config.DataConfig.toDTO(DataConfig.java:366)
        at org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:67)
        at org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
        at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
        at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
        at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
        at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
        at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
        at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
        at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
        at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
        at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
        at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
        at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
        at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
        at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:269)
        at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
        at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:193)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
        at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
        at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
Sébastien Geindre ha scritto:
hi again,
I think you're seeing http://jira.codehaus.org/browse/GEOS-1347
Thank you very much for the stack trace btw)
Chris, I guess we may want to reschedule this one for 1.6.0beta4
and 1.5.4 too (from this stack trace I believe it's related to
the native bbox caching we introduced in 1.5.3).
