On Tue, Apr 28, 2015 at 10:59 AM, Stefan Engelhardt | HBT <
Stefan.Engelhardt@anonymised.com> wrote:
Dear list,
we are using an older version of GeoServer (2.1.3) and currently we try to
improve the quality of the icons.
Here you can see an example:
http://map2.hbt.de/geoserver/gwc/service/wms?HEIGHT=256&WIDTH=256&LAYERS=geofox_workspace%3Ageofoxdb_servicestellen&STYLES=geofox_servicestellen&SRS=EPSG%3A900913&FORMAT=image%2Fpng&TILED=true&TRANSPARENT=true&TILESORIGIN=-20037508.34%2C-20037508.34&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=1100693.2063094,7093356.2227938,1103139.1912141,7095802.2076984
As you can see the text is very diffuse and we would like to get it
sharper. Our research in the GeoServer configuration and in the Internet
were not successful, I just found a setting for disabling the Antialiasing
for WMS.
You will have to upgrade GeoServer, we fixed the placement of icons around
the 2.5.x series. There are no configurations you can tune in 2.1.x to
improve that, as far as I remember at least.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
