[Geoserver-users] include external SLD
Hi
I use the geoserver for a weather project, and since 2 days I am trying to use external SLD.
In the documentation (http://geoserver.org/display/GEOSDOC/SLD+Intro+Tutorial) I read about 2 ways to realize it.
  1. To include it as POST Variable (&sld=urlto.sld
  2. In the OpenLayer definition
// setup untiled layer
untiled = new OpenLayers.Layer.WMS.Untiled(
“sf:dem”, “http://195.1.161.164:8080/geoserver/wms”,
height: ‘552’,
width: ‘800’,
layers: ‘sf:dem’,
styles: ‘’,
srs: ‘EPSG:26713’,
sld: ‘http://localhost/mysldfile.sld’,
format: ‘image/png’
{maxExtent: bounds, maxResolution: 74.1796875, projection: “EPSG:26713”}
I tested it with a geoserver on linux( Version 1.73 and 1.74 and both doesn’t work
Actual my SLD only work if i paste it with the Style Editor
I need only a way, without post the sld in the geoserver interphase(Styles) and without reload the server
Or should I use it with a database solution?
My example is on:
http://81.31.132.74:8081/geoserver/wms?bbox=450344.9587958323,55225.699580058084,864725.7694390065,325778.39296580886&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:shape_CH&width=800&height=490&srs=EPSG:4151
with sld i used following url
http://81.31.132.74:8081/geoserver/wms?bbox=450344.9587958323,55225.699580058084,864725.7694390065,325778.39296580886&sld=http://login.comventus.com/sld/shape_CH_style.sld&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:shape_CH&width=800&height=490&srs=EPSG:4151
my url to my sld = http://login.comventus.com/sld/shape_CH_style.sld
Thank you
Guido Schratzer
E-Mail-Nachricht wurde von Internet Security ?berpr?ft (6.0.1.440)
Datenbankversion: 6.12500
http://www.pctools.com/internet-security/
Guido Schratzer ha scritto:
Hi
            "sf:dem", "http://195.1.161.164:8080/geoserver/wms",
              height: '552',
              width: '800',
              layers: 'sf:dem',
              styles: '',
              srs: 'EPSG:26713',
              sld: 'http://localhost/mysldfile.sld’,
              format: 'image/png'
            {maxExtent: bounds, maxResolution: 74.1796875, projection: "EPSG:26713"}
Using a SLD within a request requires some matching between the
SLD and the layer.
It's been a while since I last played with external SLD, but as
far as I rember you have to give the NamedLayer the proper name: <Name>topp:shape_CH</Name>
and then either:
- mark the style as the default one (<UserStyle> should
   have <default>true</default> element)
- give the user style a name and refer to it in your request
   (&sld=...&styles=styleName).
As a final alternative, don't mention neither the layer names
and styles in the GetMap request and put everything in the SLD
with proper names.
Hope this helps
Andrea Aime
OpenGeo - http://opengeo.org
Hi Andrea,
thank you very much!
The external SLD now working:
The Problem was
1. in the url i can't use the Port 8001
2. <Name>topp:shape_CH</Name> // name topp:shape_CH (Layername)
Best regards
Guido
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet: Freitag, 29. Mai 2009 18:33
An: Guido Schratzer
Betreff: Re: [Geoserver-users] include external SLD
Hi
ways to realize it.
            "sf:dem", "http://195.1.161.164:8080/geoserver/wms&quot;,
              height: '552',
              width: '800',
              layers: 'sf:dem',
              styles: '',
              srs: 'EPSG:26713',
              format: 'image/png'
"EPSG:26713"}
doesn't work
SLD and the layer.
and then either:
with proper names.
Hope this helps
Andrea Aime
