[Geoserver-users] Incorrect Results With Geometry Filter
Thanks for the response.
This is with shapefile datastore? Is it the same on postgis?
Yes, the results I saw were with a shapefile-backed feature type (sorry,
I might have mentioned that). I tried a query against a postgis-backed
feature type and got correct results. So according to my tests, postgis
works, shapefile does not. The problem seems to lie with the Touches
filter, as a simple Touches request returns no results, where there
should be 20 results according to JTS.
Go ahead and report this as a bug. Could you also set the logging to
'finer' and attach the logs to the issue you report.
I'll report the bug. I unfortunately don't have the logs handy (remote
geoserver), but I'll attach the query and server url to the report.
Hopefully that'll be enough to go on.
Also go ahead and report that the Relates function doesn't work.
Has been reported (GEOS-637)
best regards,
Chris
John Fletcher
Latitude Geographics Group Ltd.
jfletcher@anonymised.com www.latitudegeo.com
Head Office: 204 Market Square Victoria, BC Canada V8W 3C6
Tel: (250) 381-8130 Fax: (250) 381-8132
Geocortex Internet Mapping (www.geocortex.net) - Helping people succeed
with web-based geography
