Looking at the old exception,
it seems to me that the problem you are experiencing is simply that
you created external overviews (which are not handled at the moment)
for the various tiff of your mosaic.
Then you configured the mosaic to look for those external overvies
which cause it to choke since the overviews where not embedded in the
tiff file (that why the message:
Caused by: java.lang.IndexOutOfBoundsException: imageIndex out of bounds!
at com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader.seekToImage(TIFFImageReader.java:307)
Notice that adding support for external overviews would not be too
difficult to achcieve.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Jan 28, 2009 at 10:39 AM, acangi <aca@anonymised.com> wrote:
I was generating the overviews using
gdaladdo -r mode file.tif 2 4 8 16
and saw in the man page of gdaladdo that the 'mode' downsampling algorithm
wasn't implemented yet. Nevertheless, trying "-r nearest" gives the same
IndexOutOfBoundsException.
I converted my tif + tfw files to geotiff ones, generated overviews in those
geotiff files, and made the mosaic, it works.
The only problem is that I have to create geotiff files, instead of using
the tif + tfw which already exist, increasing the amount of data to maintain
and the disk space needed.
I think the problem might come from the .tif.ovr files, that geoserver
doesn't handle yet. Or does it ?
acangi wrote:
When trying to view coverages using the openlayers client provided with
GeoServer 1.7.2 (I didn't check for 1.7.1 if it's exactly the same error,
but I also had problems), I see a white screen and an exception :
"All factories fail for the operation ImageRead" ... Caused by ...
IndexOutOfBoundsException at
com.sun.media.imageioimpl.plugins.tiff.TIFFImageReader.seekToImage. If I
zoom far enough, I get rid of the error and see the maps, but zooming out
shows the problem again.
The data I'm trying to display is a set of four tif + tfw files for which
I created overviews using gdaladdo (the data is read-only, it creates a
.tif.ovr file), then grouped in a mosaic using gdaltindex -tileindex.
Viewing a single tif + tfw file for which I created overviews works fine.
It also works for a mosaic of four tif + tfw files without overviews.
Sometimes in these 2 cases I have an exception :
NumberFormatException : empty String at
sun.misc.FloatingDecimal.readJavaFormatString, but resending the request
solves this problem.
Attached a part of the log file showing the error :
http://www.nabble.com/file/p21663083/ImageIndexOutOfBounds.log
How to get rid of the IndexOutOfBoundsException ?
View this message in context: http://www.nabble.com/IndexOutOfBoundsException-tp21663083p21702577.html
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
