[Geoserver-users] Ingestion file problem in GeoServer
I’m in trouble about managing the flow from GeoBatch to GeoServer.
When I give an input tif file to GeoBatch, it starts the process to serve it to GeoServer, but it stops at 30%. So I noticed the lock and I deleted the image. Then, the process starts again (it fails, of course) and at the end in GeoServer is created an empty store.This is the error:
INFO FileBasedEventGenerator$GBEventListener - Event: FILE_ADDED /cartella/prova/immagine.tif
INFO LoggingProgressListener - Started
INFO LoggingProgressListener - Progressing 10.0% – Managing events
INFO LoggingProgressListener - Progressing 20.0% – Creating backup dir
INFO FileBasedEventConsumer - [pool-2-thread-5]: new element retrieved from the MailBox.
INFO LoggingProgressListener - Progressing 30.0% – Preprocessing event immagine.tif
At this point the process is stopped. When I delete the image, it starts again:
INFO LoggingProgressListener - Progressing 40.0% – Creating backup files
INFO FileBasedEventConsumer - [pool-2-thread-3]: accepted file /cartella/prova/immagine.tif
INFO FileBasedEventConsumer - [pool-2-thread-3]: new element processed.
INFO LoggingProgressListener - Progressing 50.0% – Running actions
INFO LoggingProgressListener - Progressing 0.0% – Running GEOBATCH Script(1/1)
INFO ScriptingAction - Runtime class-loading from moduleFolder → /cartella/prova/config/jars
INFO ScriptingAction - Adding script property: geoserverPWD : password
INFO ScriptingAction - Adding script property: geoserverUID : userid
INFO ScriptingAction - Adding script property: defaultNamespace : default
INFO ScriptingAction - Adding script property: restGeoserverURL : http://localhost:8181/geoserver
INFO ScriptingAction - Adding script property: maxNumberCoverage : 290
INFO Logger$info -
-------------------------------- GEOBATCH SCRIPT
INFO Logger$info - ***GeoServerRestReader------> it.geosolutions.geoserver.rest.GeoServerRESTReader@anonymised.com
INFO Logger$info - ***GeoServerRestPublisher------> it.geosolutions.geoserver.rest.GeoServerRESTPublisher@anonymised.com
INFO Logger$info - Filename input:immagine
INFO Logger$info - Check convention filename
INFO Logger$info - File is valid for convention
INFO Logger$info -
— 1. ACTION WORKSPACE
INFO Logger$info - WS inputFileName: workspace
INFO Logger$info - Retrieve ws from the geoserver…
INFO GeoServerRESTReader - Loading from REST path /rest/workspaces.xml
INFO Logger$info - lista dei workspaces.… it.geosolutions.geoserver.rest.decoder.RESTWorkspaceList@anonymised.com
INFO Logger$info - WS workspace exists and applied.
INFO Logger$info -
— 2. ACTION STYLE
INFO Logger$info - Style inputFileName: style
INFO Logger$info - Retrieve styles from the geoserver…
INFO GeoServerRESTReader - Loading from REST path /rest/styles.xml
INFO Logger$info - STYLE style exists and applied.
INFO Logger$info -
— 3. ACTION DATE CHECK LAYER
INFO Logger$info - Check layer date :layer
INFO Logger$info - Retrieve layer with prefix :::immagine
INFO GeoServerRESTReader - Loading from REST path /rest/layers.xml
INFO Logger$info - MAX NUMBER COVERAGES:290
INFO Logger$info - NUMBER SAME COVERAGES LOADED:0
INFO Logger$info - NEW DATE arrived: date
INFO Logger$info -
— 4. PUBLISHED
INFO HTTPUtils - HTTP Created:
INFO GeoServerRESTPublisher - Store successfully created using ( file: /cartella/prova/immagine.tif)
WARN HTTPUtils - Bad response: code[500] msg[Internal Server Error] url[http://localhost:8181/geoserver/rest/workspaces/workspace/coveragestores/immagine/coverages.xml] method[PostMethod]: :Failed to create reader from file:/cartella/prova//immagine.geotiff and hints Hints:
FORCE_AXIS_ORDER_HONORING = http
GRID_COVERAGE_FACTORY = GridCoverageFactory
TILE_ENCODING = null
EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 3, active threads = 0, queued tasks = 0, completed tasks = 3]
LENIENT_DATUM_SHIFT = true
STYLE_FACTORY = StyleFactoryImpl
FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
COMPARISON_TOLERANCE = 1.0E-9
FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
FILTER_FACTORY = FilterFactoryImpl
ERROR GeoServerRESTPublisher - Error creating coverage workspace:store:layer (null)
ERROR GeoServerRESTPublisher - Unable to create a coverage store for coverage: /cartella/prova/immagine.tif
INFO Logger$info -
— 5. ACTION INTERPOLATION
INFO Logger$info - Interpolation inputFileName: BL
WARN HTTPUtils - Bad response: code[404] msg[Not Found] url[http://localhost:8181/geoserver/rest/workspaces/workspace/coveragestores/store/coverages/store] method[PutMethod]: No such coverage: workspace,store,layer
INFO Logger$info - Interpolation update to BILINEAR
INFO Logger$info -
— 6. ACTION SET LAST_LOADED
INFO Logger$info - ---->class org.postgresql.Driver<----
INFO Logger$info - Split Name File to product Id properly Started…
INFO Logger$info - ---->[workspace, style, interpolation, srs, immagine, data]<----
INFO Logger$info - Id product identified is: immagine
INFO Logger$info - Connection Established…!!!
INFO Logger$info - SQL update for last_loaded Started…!!!
INFO Logger$info - SQL update Executed…!!!
INFO Logger$info - Last_loaded updated is: immagine
INFO Logger$info - Connection Properly Closed…!!!
INFO Logger$info - -------------------------------- DONE!!!
INFO BaseEventConsumer - There are 1 events left in the queue after last action (GEOBATCH Script)
INFO LoggingProgressListener - Progressing 100.0% – Running actions
INFO FileBasedEventConsumer - pool-2-thread-3 DONE!
INFO LoggingProgressListener - Completed
