[Geoserver-users] InputTransparentColor for all the layers
I would like to set the InputTransparentColor to “000000” to all the layers I already have in GeoServer (around 435).
There is some options to set transparency to RBG rasters like using gdalwarp -dstnodata 0 -dstalpha options and then use the default raster style in GeoServer.
The point here is we wouldn’t like to do more processing to the script and upload again all those layers.
So my question is if it is possible to set the InputTransparencyColor to “000000” using the rest api or any other way.
Thank you in advance,
Alberto
Hi Alberto,
I think that you can do that using REST with a command like this for all coverages:
curl -v -u $USER:$PASS -XPUT -H “Content-type: text/xml” -d @“/path/to/coverageconfig.xml” “http://$HOST:$PORT/geoserver/rest/workspaces/$WORKSPACE/coveragestores/$COVERAGESTORE/coverages/$COVERAGE”
Make sure to use actual values instead of $PARAMETER.
coverageconfig.xml should contain the coveragename as well as the current parameters list (you can retrieve them from the current coverage.xml), being updated with your InputTransparentColor value.
Hope this helps.
Daniele
On Mon, Jan 25, 2016 at 11:19 AM, Alberto Callejas Delgado <alberto.callejas@anonymised.com> wrote:
Alberto
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Daniele,
Thank you very much for your help.
I just discovered this is the piece I need in my coverageconfig.xml file.
#000000
The issue is we are using the same name for store name and layer name, so I can not use the same coverageconfig.xml for all the layers. I tried creating a coverage store first and then :
curl -v -u $USER:$PASS -XPUT -H “Content-type: text/xml” -d “file:/C:\Users\coverageconfig.xml” “http://$HOST:$PORT/geoserver/rest/workspaces/$WORKSPACE/coveragestores/$COVERAGESTORE/coverages/$COVERAGE”
Maybe I need to find the way to add the InputTransparentColor into the xml once the layer has been uploaded to GeoServer?
Thank you,
Alberto
On 25 January 2016 at 17:28, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Alberto,
Hope this helps.
Daniele
Alberto
