[Geoserver-users] Insert shapefile in database (store) via API Rest
Hi All,
I want to take out a doubt. I have a shapefile and want to add it to GeoServer, via Rest.
It is possible via Rest, I submit to this shapefile, it is inserted to a store postgis (or any other database), that is being created the table and inserted the records and in the end have the layer created in geoserver in store (postgis)?
If so, how?
Best Regards,
Fernando Quadro
http://www.fernandoquadro.com.br
http://br.linkedin.com/in/fernandoquadro/
Hallo Fernado,
Have you ever seen this material, I used it once and works fine!
http://docs.geoserver.org/latest/en/user/rest/examples/curl.html
On Tue, Jan 12, 2016 at 2:42 PM, Fernando Quadro <fsquadro@anonymised.com> wrote:
Hi All,
If so, how?
Best Regards,
Fernando Quadro
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Daniel Bevilacqua
cel +55 19 81383157
Daniel,
Thanks, but you come to test? I found this link, but I still have doubt, because when it comes to creating the table, I only see him through the table structure and not the data / records to populate the new table / layer.
And that’s what I need.
2016-01-12 14:58 GMT-02:00 Daniel Bevilacqua <danielunesp02@anonymised.com>:
Hallo Fernado,
Fernando Quadro
Hi All,
If so, how?
Best Regards,
Fernando Quadro
Daniel Bevilacqua
cel +55 19 81383157
Hi Fernando,
you may want to take a look at the Importer extension:
http://docs.geoserver.org/latest/en/user/extensions/importer/index.html
It also comes with a REST API:
http://docs.geoserver.org/latest/en/user/extensions/importer/rest_reference.html
http://docs.geoserver.org/latest/en/user/extensions/importer/rest_examples.html
Hope this helps.
On Tue, Jan 12, 2016 at 6:11 PM, Fernando Quadro <fsquadro@anonymised.com> wrote:
Daniel,
Fernando Quadro
Hallo Fernado,
Hi All,
If so, how?
Best Regards,
Fernando Quadro
Daniel Bevilacqua
cel +55 19 81383157
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via Poggio alle Viti 1187
55054  Massarosa (LU)
fax:     +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Stefano,
I think it will help me yes. I will look, and if I have questions, I return to post.
Best regards,
2016-01-13 6:36 GMT-02:00 Stefano Costa <stefano.costa@anonymised.com>:
Hi Fernando,
Hope this helps.
Fernando Quadro
Daniel,
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Fernando Quadro
Hallo Fernado,
Hi All,
If so, how?
Best Regards,
Fernando Quadro
Daniel Bevilacqua
cel +55 19 81383157
