[Geoserver-users] inserting features with WFS-T into Oracle Spatial data store fails because of incorrect SRID
Hello Chris,
Thank You for this information.
I am a C# developer and do not know much very much about Java, but I am sure that I can do it, if You can show me, where to look in the code. But the change should go back somehow to the trunk of GeoServer (or GeoTools?), so that others can profit from the bug fix too and I do not have to do the same changes in the next version of GeoServer again. As I am new to GeoServer, I do not know´, how to contribute or if this is possible or desired by the developers at all.
Gerhard
Gerhard Sommer
Magistrat Wien (MA 14-ADV), Rathausstraße 1, 1082 Wien, Austria
E-Mail: som@anonymised.com
Tel: +43 (1) 4000 91326
Fax: +43 (1) 4000 99 91326
-----Original Message-----
From: Chris Holmes *EXTERN* [mailto:cholmes@anonymised.com]
Sent: Wednesday, June 07, 2006 7:04 PM
To: Sommer Gerhard
Subject: Re: [Geoserver-users] inserting features with WFS-T
The Oracle Datastore hasn't had as much QA as PostGIS for example.
There's likely a bug in the code. If you're able to get in
to the Java
I'm happy to point you where to look to fix the problem. I doubt it
should be that hard to fix...
Chris
Sommer Gerhard wrote:
> Hello,
> I am currently evaluating, if GeoServer (1.3.1) WFS-T can
be used to edit data in Oracle Spatial (10g) feature types.
> My feature type is in EPSG:31286 coordinate system, but
GeoServer seems to always insert features with Oracle SRID 0
into the Oracle Spatial layer.
> SRID = 0 is not defined in the USER_SDO_GEOM_METADATA
table. Therefore, if I try to create a spatial index, this is
not possible as the SRID values differ (I have 31286 in
USER_SDO_GEOM_METADATA, corresponding to the EPSG code of my
data). On the other hand, if I already have a spatial index
on my data and try to insert geometry using GeoServer, I also
get an the error message, that SRID of the geometry does not
match the SRID of USER_SDO_GEOM_METADATA.
> What can I do to solve this problem? Or is this a bug in
the current GeoServer version?
> Best Regards,
> Gerhard
> Gerhard Sommer
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> !DSPAM:1003,4486ee74256461460912952!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Yes, not only is it desired to go back to trunk, but I probably wouldn't give you help if you weren't going to contribute it back.
Ok, the code is all in GeoTools. The two classes are:
http://svn.geotools.org/geotools/branches/2.2.x/plugin/oraclespatial/src/org/geotools/data/oracle/OracleFeatureWriter.java
and
http://svn.geotools.org/geotools/branches/2.2.x/plugin/oraclespatial/src/org/geotools/data/oracle/sdo/GeometryConverter.java
I don't have the time to dig in to the exact solution, but I can give you a few hints. The function SDO.toSDO(geometry) tries to extract the srid from the geometry itself. The problem is that the SRID number is usually not set on the JTS geometry, because it's relatively meaningless.
So the first thing to try would be to get the proper srid. You can get it from the queryData's featureTypeInfo I think. You'll have to dig in to the parent classes, more in main module, the org.geotools.data.jdbc package and org.geotools.data.
After you get the SRID, you can try just setting it on the geometry. If that doesn't work you could redo that toSDO function to take an SRID.
hope this helps, if you need more help I can try to find some more time to dig in to it.
Chris
Hello Chris,
Gerhard
Gerhard Sommer
From: Chris Holmes *EXTERN* [mailto:cholmes@anonymised.com] Sent: Wednesday, June 07, 2006 7:04 PM
To: Sommer Gerhard
Subject: Re: [Geoserver-users] inserting features with WFS-T into Oracle Spatial data store fails because of incorrect SRID
The Oracle Datastore hasn't had as much QA as PostGIS for example. There's likely a bug in the code. If you're able to get in to the Java I'm happy to point you where to look to fix the problem. I doubt it should be that hard to fix...
Chris
Hello,
GeoServer seems to always insert features with Oracle SRID 0 into the Oracle Spatial layer.
table. Therefore, if I try to create a spatial index, this is not possible as the SRID values differ (I have 31286 in USER_SDO_GEOM_METADATA, corresponding to the EPSG code of my data). On the other hand, if I already have a spatial index on my data and try to insert geometry using GeoServer, I also get an the error message, that SRID of the geometry does not match the SRID of USER_SDO_GEOM_METADATA.
Best Regards,
Gerhard
Gerhard Sommer
Chris Holmes
!DSPAM:1003,4487d778202316309890654!
Chris Holmes
