Hello List,
I found out that inserting the File schema.xml for FeatureType has no effect
for DescribeFeatureType-Requests in WFS Version 1.1.0.
Is this correct?
I have got the Problem that I have to specify the GeometryPropertyType to
LineStringPropertyType when I use the Oracle-Plugin to prevent inserting
Features with other Geometries than LineStrings.
Is there any possibility to do that?
Thanks a lot
Tim
Hi Tim,
Changing it to schema.xsd should do the trick. Although it is not something we promote all that much since its a bit of a hack.
All: I never quite understood what schema.xml did. I thought it was linked to the UI somehow, but something that never got properly hooked up. If indeed it should be support we have a regression here.
-Justin
Tim Englich wrote:
Hello List,
Is this correct?
Thanks a lot
Tim
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,47df5f93112642458217002!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi Tim,
I'm a newbie to GeoServer and am having problems getting it to play nicely
with Oracle.
The only table I have been able to get to work properly has been a test
table in which I enforced the geometries to be points .. I am starting to
come to the conclusion that GeoServer's Oracle support is limited - does
your post suggest that you are having similar experiences?
http://www.nabble.com/Newbie---1.6.1-WFS-version-question-td16004690.html
myPost
Tim Englich-2 wrote:
Hello List,
Thanks a lot
Tim
View this message in context: http://www.nabble.com/Inserting-schema.xml-for-FeatureType-has-no-effect-for-WFS-Version-1.1.0-tp16115107p16122634.html
