I am very new to using GeoServer and I am experiencing troubles with doing simple tasks like creating a new Store. To be exact, I am getting a spinning wheel when I attempt to do a lot of things. I can see and use the example services that come with the basic install and I can create new Workspaces; however, I cannot delete any Workspaces or create a new Store.
I am on Windows Server 2012 with JRE 7 installed and I am currently the Administrator for both the server and the GeoServer. Thanks in advance for any help.
-Tom Hoober
any help.
Cannot be sure, but maybe you don't have write permissions in the location
containing the geoserver data directory.
When I say you, I really mean the user running the GeoServer, which can be
different if you are starting it as a service
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Tom,
If you look in the GeoServer.log file, it’ll usually indicate what the problem is; anything with an ERROR likely to be causing a problem. WARNS are also something that may or may not be worth investigating (but many aren’t).
You may want to increase your logging level too.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 24 October 2013 09:34, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Oct 23, 2013 at 7:55 PM, Tom Hoober <THoober@anonymised.com> wrote:
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Cannot be sure, but maybe you don’t have write permissions in the location containing the geoserver data directory.
When I say you, I really mean the user running the GeoServer, which can be different if you are starting it as a service
Ing. Andrea Aime
@geowolf
Technical Lead
I am not 100% sure what it was. Personally I believe it was 64 bit vs 32 bit JRE. I rolled back to a pre-install snapshot and redid it with 32 bit and everything seems to be working. I also ensured I locked my IP (I am working on a VM where it jumped around a little bit) and had the JRE installed before I started GeoServer installation. Everything is smooth sailing now.
Tom Hoober
Hi Tom,
Jonathan
Ing. Andrea Aime
@geowolf
Technical Lead
