Hello everybody, i´m new with Geoserver, i´ve made today the installation
over windows xp. I have j2sdk 1.4 and geoserver 1.7. All seems to go ok
during the installation, but when i try to start geoserver, it doesn´t work,
i get this message:
10 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com v
ia org.mortbay.log.Slf4jLog
1913 [main] WARN org.mortbay.log - Deprecated configuration used for
C:\GeoServe
r 1.7.0-alpha1/webapps
2113 [main] INFO org.mortbay.log - jetty-6.1.8
3675 [main] ERROR org.mortbay.log - failed
org.mortbay.jetty.webapp.WebAppContex
t@anonymised.com{/geoserver,file:/C:/GeoServer%201.7.0-alpha1/webapps/geoserver/}
java.lang.UnsupportedClassVersionError:
org/geoserver/GeoserverInitStartupListen
er (Unsupported major.minor version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
at
java.security.SecureClassLoader.defineClass(SecureClassLoader.java:12
3)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at
org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoade
r.java:366)
at
r.java:337)
at
org.mortbay.jetty.handler.ContextHandler.loadClass(ContextHandler.jav
a:1035)
at
org.mortbay.jetty.webapp.WebXmlConfiguration.initListener(WebXmlConfi
guration.java:629)
at
org.mortbay.jetty.webapp.WebXmlConfiguration.initWebXmlElement(WebXml
Configuration.java:367)
at
org.mortbay.jetty.webapp.WebXmlConfiguration.initialize(WebXmlConfigu
ration.java:289)
at
org.mortbay.jetty.webapp.WebXmlConfiguration.configure(WebXmlConfigur
ation.java:222)
at
org.mortbay.jetty.webapp.WebXmlConfiguration.configureWebApp(WebXmlCo
nfiguration.java:180)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1217)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
at
39)
at
.java:152)
at
39)
at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at
39)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
3735 [main] ERROR org.mortbay.log - failed ContextHandlerCollection@anonymised.com...
at
3)
at
r.java:366)
at
r.java:337)
at
a:1035)
at
guration.java:629)
at
at
ration.java:289)
at
ation.java:222)
at
at
a:1217)
at
510)
at
at
39)
at
.java:152)
at
at
39)
at
.java:152)
at
39)
at
130)
at
39)
at
java:39)
at
sorImpl.java:25)
3916 [main] INFO org.mortbay.log - Opened C:\GeoServer
1.7.0-alpha1\logs\2008_05
_18.request.log
3926 [main] ERROR org.mortbay.log - failed HandlerCollection@anonymised.com
at
3)
at
r.java:366)
at
r.java:337)
at
a:1035)
at
guration.java:629)
at
at
ration.java:289)
at
ation.java:222)
at
at
a:1217)
at
510)
at
at
39)
at
.java:152)
at
at
39)
at
.java:152)
at
39)
at
130)
at
39)
at
java:39)
at
sorImpl.java:25)
3956 [main] ERROR org.mortbay.log - Error starting handlers
at
3)
at
r.java:366)
at
r.java:337)
at
a:1035)
at
guration.java:629)
at
at
ration.java:289)
at
ation.java:222)
at
at
a:1217)
at
510)
at
at
39)
at
.java:152)
at
at
39)
at
.java:152)
at
39)
at
130)
at
39)
at
java:39)
at
sorImpl.java:25)
4286 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
and if i try to open the Geserver Administration, this is the message:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/geoserver/
Powered by jetty://
What i´m doing wrong, can anybody help me??
Thank you very much
View this message in context: http://www.nabble.com/Install-problem-tp17304194p17304194.html
