[Geoserver-users] install
I know there are some tutorials about installation… but I have a long tradition being a “blackbox user” and I found different instructions in different places, so I still have a couple of questions as I will be installing all from scratch in a new machine (I cannot even trust my current directories, because after trying to update geoserver i had to uninstall and install again… I was untidy so now all my directories are a mess)
  1. Do I need Tomcat? I thought I did, I followed some tutorial to install it, but now I realize it is not instructed here: http://geoserver.org/display/GEOSDOC/1.1.1+Windows+Install
  2. So I did install it, and I think its alright (when I run the startup.bat I see the congratulations message browsing http://localhost:8080). But if I have Geoserver runnning in http://localhost:8080 I get Error 404… is that supposed to happen? do i have these servers correctly?
  3. I think I installed the .war, but now I could only find the instructions for the .exe… why? what are the differences? which should i get?
  4. where is it best to install geoserver? somewhere I found inside the apache/webapps directory was best??
  5. Is it possible to install Postgre/PostGIS somewhere else than C:/?? I dont have administrator right so it is not convenient for me… but as I recall inside C:/ was my only option
and 1 comment: I think there is a lot of material, very (or too) detailed on (very) basic things (for example how to add a shapefile to geoserver) but then, there is a very big gap from all the bascis to actually doing some things… maybe it is just my varied background and lack of “computer” and databases knowledge, but when the tutorials or books tell me “now you are ready to go” I fell at a complete loss. I feel the jump is from “click here” to developers
Thank you very much!
Virginia.
See all the ways you can stay connected to friends and family
1) If you download the Windows installer you should not install Tomcat or the WAR file. The Windows installer comes with a Tomcat-equivalent named Jetty and this causes collisions (on the port number), so you should uninstall Tomcat.
2) What you're seeing is Jetty , which has no content for / , hence the 404.
3) The WAR is for Tomcat and similar containers. Ignore it.
4) Default install location for the Windows installer is fine. (If you do use Tomcat / WAR then it does have to go into the webapp directory)
5) You should be able to choose the location during installation, perhaps by going through "Advanced" or customize. That would probably be a question for the postgis list.
It's a bit outdated in terms of the colors, but essentially the tutorial for adding shapefiles is http://geoserver.org/display/GEOSDOC/User+Tutorial+Shapefile (via tutorials page http://geoserver.org/display/GEOSDOC/Tutorials) . It's a bit tricky to provide the next steps after the installation, because that's where everyone start making their own choices. We're working on better documentation though.
Hope that helps,
-Arne
virginia antonijevic wrote:
I know there are some tutorials about installation... but I have a long tradition being a "blackbox user" and I found different instructions in different places, so I still have a couple of questions as I will be installing all from scratch in a new machine (I cannot even trust my current directories, because after trying to update geoserver i had to uninstall and install again... I was untidy so now all my directories are a mess)
1) Do I need Tomcat? I thought I did, I followed some tutorial to install it, but now I realize it is not instructed here: http://geoserver.org/display/GEOSDOC/1.1.1+Windows+Install
2) So I did install it, and I think its alright (when I run the startup.bat I see the congratulations message browsing http://localhost:8080). But if I have Geoserver runnning in http://localhost:8080 I get Error 404.... is that supposed to happen? do i have these servers correctly?
3) I think I installed the .war, but now I could only find the instructions for the .exe... why? what are the differences? which should i get?
4) where is it best to install geoserver? somewhere I found inside the apache/webapps directory was best??
5) Is it possible to install Postgre/PostGIS somewhere else than C:/?? I dont have administrator right so it is not convenient for me... but as I recall inside C:/ was my only option
and 1 comment: I think there is a lot of material, very (or too) detailed on (very) basic things (for example how to add a shapefile to geoserver) but then, there is a very big gap from all the bascis to actually doing some things... maybe it is just my varied background and lack of "computer" and databases knowledge, but when the tutorials or books tell me "now you are ready to go" I fell at a complete loss. I feel the jump is from "click here" to developers
Virginia.
See all the ways you can stay connected to friends and family <http://www.microsoft.com/windows/windowslive/default.aspx&gt;
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
