This the start up log on the dos console of geoserver.............
- Loading XML bean definitions from URL
[jar:file:/C:/Program%20Files/GeoServer%
201.5.1/webapps/geoserver/WEB-INF/lib/validation-1.5.1.jar!/applicationContext.x
ml]
25036 [main] INFO
org.springframework.beans.factory.xml.XmlBeanDefinitionReader
[file:/C:/Program%20Files/GeoServer%201.
5.1/webapps/geoserver/WEB-INF/classes/applicationContext.xml]
25256 [main] INFO
201.5.1/webapps/geoserver/WEB-INF/lib/wfs-1.5.1.jar!/applicationContext.xml]
25817 [main] INFO
org.springframework.web.context.support.XmlWebApplicationConte
xt - Bean factory for application context [Root WebApplicationContext]:
org.spri
ngframework.beans.factory.support.DefaultListableBeanFactory defining
beans [wcs
,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGe
tCapabilities,wcsDescribeCoverage,wcsGetCoverage,config,geoServer,globalConfig,d
ata,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoSer
verRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,par
tialBufferServiceStrategy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAb
stractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribe
FeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsP
utStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFacto
ry,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,Tiff
MapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFac
tory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLaye
rsMapProducerFactory,catalog,serviceFinder,validation,validationConfig,validatio
nRegisterar,validationConfigRegisterar,applicationState,applicationStateRegister
ar,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService
,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFe
atureWithLock,wfsTransaction]; root of BeanFactory hierarchy
26167 [main] INFO
xt - 71 beans defined in application context [Root WebApplicationContext]
26578 [main] INFO org.springframework.core.CollectionFactory - Commons
Collectio
ns 3.x available
26879 [main] INFO
xt - Unable to locate MessageSource with name 'messageSource': using
default [or
g.springframework.context.support.DelegatingMessageSource@anonymised.com]
26969 [main] INFO
xt - Unable to locate ApplicationEventMulticaster with name
'applicationEventMul
ticaster': using default
[org.springframework.context.event.SimpleApplicationEve
ntMulticaster@anonymised.com]
27009 [main] INFO
org.springframework.ui.context.support.UiApplicationContextUti
ls - Unable to locate ThemeSource with name 'themeSource': using default
[org.sp
ringframework.ui.context.support.ResourceBundleThemeSource@anonymised.com]
27019 [main] INFO
org.springframework.beans.factory.support.DefaultListableBeanF
actory - Pre-instantiating singletons in factory
[org.springframework.beans.fact
ory.support.DefaultListableBeanFactory defining beans
[wcs,wcsConfig,wcsRegister
ar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescr
ibeCoverage,wcsGetCoverage,config,geoServer,globalConfig,data,dataConfig,dataReg
isterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedSer
viceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrat
egy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsServi
ce,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeat
ureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,
wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFa
ctory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVG
MapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFac
tory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,c
atalog,serviceFinder,validation,validationConfig,validationRegisterar,validation
ConfigRegisterar,applicationState,applicationStateRegisterar,wfs,wfsConfig,wfsRe
gisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wf
sDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTrans
action]; root of BeanFactory hierarchy]
- GEOSERVER_DATA_DIR: C:\Program Files\GeoServer 1.5.1\data_dir
30 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - logging level
is CON
FIG
251 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - maxFeatures
is 1000
000
251 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - numDecimals
returni
ng is 8
251 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - charSet is UTF-8
441 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - reading
srsXmlStyle
: [srsXmlStyle: null]
441 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - No baseMap
groups d
efined yet
441 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurati
on file: C:\Program Files\GeoServer 1.5.1\data_dir\catalog.xml
571 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xml
ns:topp="http://www.openplans.org/topp", isDefault=true
namespace xml
ns:sde="http://geoserver.sf.net", isDefault=false
namespace xml
ns:nurc="http://www.nurc.nato.int", isDefault=false
581 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
namespace xml
ns:tiger="http://www.census.gov", isDefault=false
namespace xml
ns:cite="http://www.opengeospatial.net/cite", isDefault=false
651 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore DS
_giant_polygon
661 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore st
ates_shapefile
671 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore DS
_poi
datastore ta
smania_cities
datastore ta
smania_roads
datastore ta
smania_state_boundaries
701 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded
datastore DS
_poly_landmarks
datastore DS
_tiger_roads
datastore ta
smania_water_bodies
731 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
giant_
polygon
capita
ls
tiger_
roads
poly_l
andmarks
761 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
green
781 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
simple
_roads
781 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style dem
popula
tion
line
791 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
raster
polygo
n
point
791 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style poi
801 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loaded style
cite_l
akes
801 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurati
1.5.1\data_dir\featureTypes\DS_giant_polygon
_giant_polygon\info.xml
942 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType g
iant_polygon
942 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
name:
DS_giant_polygon:::giant_polygon
962 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurati
1.5.1\data_dir\featureTypes\DS_poi_poi\info.
xml
1012 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
poi
1022 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: DS_poi:::poi
1022 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
ion file: C:\Program Files\GeoServer
1.5.1\data_dir\featureTypes\DS_poly_landmar
ks_poly_landmarks\info.xml
1062 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
poly_landmarks
1112 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: DS_poly_landmarks:::poly_landmarks
1112 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\DS_tiger_roads_
tiger_roads\info.xml
1182 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
tiger_roads
1182 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: DS_tiger_roads:::tiger_roads
1182 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\states\info.xml
1552 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
states
1552 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: states_shapefile:::states
1613 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\tasmania_cities
\info.xml
1633 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
tasmania_cities
1643 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: tasmania_cities:::tasmania_cities
1643 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\tasmania_roads\
info.xml
1943 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
tasmania_roads
1983 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: tasmania_roads:::tasmania_roads
1993 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\tasmania_state_
boundaries\info.xml
2093 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
tasmania_state_boundaries
2093 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: tasmania_state_boundaries:::tasmania_state_boundaries
2093 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
1.5.1\data_dir\featureTypes\tasmania_water_
bodies\info.xml
2324 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
tasmania_water_bodies
2324 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding
file name
: tasmania_water_bodies:::tasmania_water_bodies
368470 [main] INFO org.springframework.web.context.ContextLoader - Using
context
class [org.springframework.web.context.support.XmlWebApplicationContext]
for ro
368920 [main] INFO org.springframework.web.context.ContextLoader - Root
WebAppli
cationContext: initialization completed in 352517 ms
394287 [main] INFO org.apache.struts.tiles.TilesPlugin - Tiles definition
factor
y loaded for module ''.
394487 [main] INFO org.apache.struts.validator.ValidatorPlugIn - Loading
validat
ion rules file from '/WEB-INF/validator-rules.xml'
394657 [main] INFO org.apache.struts.validator.ValidatorPlugIn - Loading
validat
ion rules file from '/WEB-INF/validation.xml'
395489 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
ContextL
oaderPlugIn for Struts ActionServlet 'action, module '': initialization
started
395509 [main] INFO /geoserver - Initializing WebApplicationContext for
Struts Ac
tionServlet 'action', module ''
395539 [main] INFO
- Loading XML bean definitions from ServletContext resource
[/WEB-INF/action-se
rvlet.xml]
395709 [main] INFO
ext - Bean factory for application context [WebApplicationContext for
namespace
'action-servlet']:
Factory defining beans [/admin/loginSubmit]; parent:
actory.support.DefaultListableBeanFactory defining beans
terar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDe
scribeCoverage,wcsGetCoverage,config,geoServer,globalConfig,data,dataConfig,data
Registerar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speed
ServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceSt
rategy2,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsSe
rvice,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetF
eatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflect
or,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProduce
rFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactory,
SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducer
Factory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactor
y,catalog,serviceFinder,validation,validationConfig,validationRegisterar,validat
ionConfigRegisterar,applicationState,applicationStateRegisterar,wfs,wfsConfig,wf
sRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities
,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTr
395789 [main] INFO
ext - 1 beans defined in application context [WebApplicationContext for
namespac
e 'action-servlet']
395789 [main] INFO
ext - Unable to locate MessageSource with name 'messageSource': using
default [o
rg.springframework.context.support.DelegatingMessageSource@anonymised.com]
395809 [main] INFO
ext - Unable to locate ApplicationEventMulticaster with name
'applicationEventMu
lticaster': using default
entMulticaster@anonymised.com]
395819 [main] INFO
ils - Unable to locate ThemeSource with name 'themeSource': using default
[org.s
pringframework.ui.context.support.DelegatingThemeSource@anonymised.com]
395839 [main] INFO
Factory - Pre-instantiating singletons in factory
ent: org.springframework.beans.factory.support.DefaultListableBeanFactory
defini
ng beans
[wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcs
Service,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,config,geoServer,g
lobalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegi
sterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,bufferServic
eStrategy,partialBufferServiceStrategy2,wms,wmsConfig,wmsRegisterar,wmsConfigReg
isterar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegac
y,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetM
apLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegend
ProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProduce
rFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLM
apProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFac
tory,OpenLayersMapProducerFactory,catalog,serviceFinder,validation,validationCon
fig,validationRegisterar,validationConfigRegisterar,applicationState,application
StateRegisterar,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractServi
ce,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFea
ture,wfsGetFeatureWithLock,wfsTransaction]; root of BeanFactory hierarchy]
395989 [main] INFO org.springframework.web.struts.ContextLoaderPlugIn -
Using co
ntext class
'org.springframework.web.context.support.XmlWebApplicationContext' f
or servlet 'action'
ContextL
oaderPlugIn for Struts ActionServlet 'action', module '': initialization
complet
ed in 500 ms
401667 [main] WARN org.mortbay.log - failed SelectChannelConnector @
0.0.0.0:808
0
401667 [main] WARN org.mortbay.log - failed Server@anonymised.com
401667 [main] WARN org.mortbay.log - EXCEPTION
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind(Native Method)
at
sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:
119)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
at
org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnec
tor.java:152)
at
org.mortbay.jetty.AbstractConnector.doStart(AbstractConnector.java:31
3)
at
org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelCon
nector.java:124)
at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
38)
at org.mortbay.jetty.Server.doStart(Server.java:217)
at
38)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:905)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Could you possibly send us the startup log which appears on the dos
console as geoserver starts up.
-Justin
ermisafrica wrote:
Dear user,
im doing my installation or both java server and geoserver according to
the
installation but when i try to access the
http://localhost:8080/geoserver
or http://localhost:8080/geoserver/demo.do i get the following
errors
down. Who can assist me: I m using s windows platform
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
Sun Java System Application Server Platform Edition 9.0_01
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Julius Githinji Muchemi
Executive Director
Environmental Research Mapping and Information Systems in Africa (ERMIS
Africa)
Gate House, 2rd Floor, Room 202
Mburu Gichua Road
PO Box 12327 NAKURU, Kenya
Tel +254 051 2213323
Mobile: +254 0720 703 606
julius@anonymised.com
www.ermisafrica.org
