Installation of geoserver-1.5.0-RC4 in linux-vserver with a recent debian
etch in it fails.
I'm starting geoserver with "GEOSERVER_HOME=/usr/local/geoserver
JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun/jre /usr/local/geoserver/bin/startup.sh".
After a few seconds it stops. Here are the last few lines (complete log file
attached):
3155 [INFO] org.geotools.referencing.factory.epsg.HSQLDataSource - Creating
cached EPSG database. It may take a few minutes.
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGBUS (0x7) at pc=0xb7e28ccf, pid=20969, tid=3084630240
# Java VM: Java HotSpot(TM) Client VM (1.5.0_10-b03 mixed mode, sharing)
# Problematic frame:
# C [libc.so.6+0x6cccf] memcpy+0x2f
# An error report file with more information is saved as hs_err_pid20969.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Aborted
Any hints how to solve this problem?
Does anybody have geoserver running in a linux-vserver? Java seems to work
right on this vserver, tested it with a another java application without
problems.
Regards
Thomas
hs_err_pid20969.log (43.6 KB)
Thomas Besser ha scritto:
etch in it fails.
JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun/jre /usr/local/geoserver/bin/startup.sh". After a few seconds it stops. Here are the last few lines (complete log file
attached):
Hum, we've had consistent issues like this one on Gentoo distributions using the JDK included in the distribution, and they have gone away using the JDK downloaded directly from the Sun site. May this be your case?
Another hint may be that your server seems to be crashing while
creating the epsg databse. Can you check you have the necessary write
permissiong on the container temp folder? Geoserver will actively try to create files in both that folder and in the unpacked war too (only for previews).
Hope this helps
case?
Unfortunately, no. Same error with jdk1.5.0_11 from sun.
previews).
Sorry, I forgot to say, that I installing it as root. So there should be IMO
no permission problem.
I will install a fresh native linux etch box to test if it fails there too.
Perhaps it is a problem of linux-vserver!?
Regards
Thomas
too. Perhaps it is a problem of linux-vserver!?
Ok, it seems to be a problem of linux-vserver. In a fresh installed etch box
the installation scripts runs through.
Regards
Thomas
Well, that given, you may want to try running geoserver on a jdk 1.6.0.
If it runs, it will be faster too
box the installation scripts runs through.
Ah, I didn't noticed that jdk1.6.0 already exists. But, no luck, same error
on linux-vserver.
Regards
Thomas
