[Geoserver-users] Installation of the jdbcconfig community module
Hi, everyone.
     I am trying to download the JDBCConfig module for installation in
my new geoserver 2.9 server, and I cannot find the file for download.
Here is what I tried:
-Read the docs at
http://docs.geoserver.org/stable/en/user/community/jdbcconfig/installing.html
-Went to http://geoserver.org/release/stable/ and clicked on
"extensions", and searched for the
geoserver-2.9.0-jdbcconfig-plugin.zip. That seemed to me to be the right
place, because there were zipfiles with the names of a lot of other
extensions.
-Did the same above for geoserver 2.8.4, found a lot of extensions, but
not this one.
-Searched again for the related module JDBCStore, also could not find it.
-Googled for geoserver-2.9.0-jdbcconfig-plugin.zip with no success
-Checked the release notes for geoserver 2.9.0 at
  http://blog.geoserver.org/2016/05/30/geoserver-2-9-0-released/
  and found a mention of the JDBCConfig module under "Resource REST
API", which leads me to believe that it is currently supported.
-Found the source at
  https://github.com/geoserver/geoserver/tree/master/src/community/jdbcconfig
  and tried to compile Geoserver from source (although that was also
motivated by a specific LDAP need of mine). Compiling from source proved
to be too much right now, I am not familiar with the codebase and
haven't programmed in java for a long time. I would like to keep
everything stock to make maintenance easier and documentation shorter.
Should the zipfile be available at the locations I looked?
Is that module current (I take it that it is since the latest commit was
15 days ago)?
Is it necessary to compile the module from source?
I apologize if I have missed something obvious. Please point me in the
right direction.
Best,
Daniel Miranda
Daniel Araújo Miranda
Forensics Expert
Inteligeo - Geographic Intelligence
National Institute of Criminalistics
Brazilian Federal Police
Community modules are not released. You can download them from the nightly builds:
http://ares.boundlessgeo.com/geoserver/2.9.x/
Nuno Oliveira
Le mardi 05 juillet 2016 à 13:08 -0300, Daniel Araujo Miranda a écrit :
Hi, everyone.
-Read the docs at
extensions.
not this one.
15 days ago)?
right direction.
Best,
Daniel Miranda
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
To complete my answer: http://docs.geoserver.org/stable/en/user/community/index.html
Le mardi 05 juillet 2016 à 17:22 +0100, Nuno Oliveira a écrit :
Nuno Oliveira
> Hi, everyone.
> -Read the docs at
> extensions.
> not this one.
> 15 days ago)?
> right direction.
> Best,
> Daniel Miranda
@nmcoliveira
Software Engineer
On Tue, Jul 5, 2016 at 6:08 PM, Daniel Araujo Miranda <
No, it's not supposed to be there. As a community module it's not
officially supported and
thus left out of releases, but you can find it among nightly builds
instead, e.g.:
http://ares.boundlessgeo.com/geoserver/2.9.x/community-latest/
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi everyone!
     In the short time I have participated in this list I have got the impression that the rate of questions asked in this list somewhat exceeds the rate of questions answered.
     It is not fair to ask more of the developers or the other geoserver volunteers, so if you know the answer to mine or any other question, please chime in.
Thanks to all, this is a great community around a great project.
--Daniel
Em 05/07/2016 13:08, Daniel Araujo Miranda escreveu:
Hi, everyone.
-Read the docs at
extensions.
not this one.
15 days ago)?
right direction.
Best,
Daniel Miranda
Document page for community modules is http://docs.geoserver.org/latest/en/user/community/index.html. Search the download from nightly builds.
Jukka Rahkonen
Lähettäjä: Daniel Araujo Miranda
Lähetetty: ‎8.‎7.‎2016 13:57
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] List participation (was: Installation of the jdbcconfig community module)
Hi everyone!
please chime in.
–Daniel
Hi, everyone.
-Read the docs at
“extensions”, and searched for the
extensions.
not this one.
and found a mention of the JDBCConfig module under “Resource REST
API”, which leads me to believe that it is currently supported.
haven’t programmed in java for a long time. I would like to keep
15 days ago)?
right direction.
Best,
Daniel Miranda
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
It is a community module, so it is not "released" and you should not expect
support. It is only made available for testing (nightly builds, as pointed
out by Jukka).
See http://ares.boundlessgeo.com/geoserver/2.9.x/community-latest/ to get
the download for 2.9.x
Brad
Thank you Brad! I found the downloadable module at the place you indicated.
     The support absence is perfectly ok. I am going for it because the functionality is absolutely awsome for my use case.
--Daniel
Em 09/07/2016 07:03, Brad Hards escreveu:
out by Jukka).
Brad
The jdbconfig module was mentioned as a community module in the release notes. It is especially difficult to ask for assistance/support on community modules where the work is not being released as part of GeoServer. We set up the “community module” idea to encourage students and companies to share their work in progress, experiments and features to encourage collaboration. Not every group is in position to meet the quality assurance and documentation requirements to have their work included in GeoServer.
If you are interested in any of the projects here https://github.com/geoserver/geoserver/tree/master/src/community you may wish to check if the work is actively maintained:
  • if the community module is not actively maintained ask on the email list if there is anyone else working on the functionality - perhaps you can combine forces? The developer responsible may need encouragement/assistance or a contract to complete the work to meet the documentation and quality assurance requirements for the Project. We have to be careful in the GeoServer community not to take on functionality that is unsupported and unmaintainable.
  • If the community module is actively maintained review the pom.xml file to determine who is taking care of it, many of these individuals are listed on our commercial support page
I do understand that community modules are frustrating, the promise of functionality that is just out of reach. We find this less frustrating then helping developers (sometimes for months) complete features that we never get to see. At least this way we have access to the source code and can build on their work (either directly by completing the functionality, or indirectly by using the work as an example/inspiration).
On 8 July 2016 at 04:54, Daniel Araujo Miranda <miranda.dam@anonymised.com> wrote:
Hi everyone!
please chime in.
–Daniel
Hi, everyone.
-Read the docs at
extensions.
not this one.
15 days ago)?
right direction.
Best,
Daniel Miranda
Jody Garnett
Hi, Jody!
     Thanks for your answer.
     I hold this community in the highest regard and I did not wish to
convey any negative idea about it. I apologize if I did that
     The idea of the community modules is great and I fully understand
the support limitations regarding these. I also understand the
limitations of community support versus paid consulting even for
supported modules. You are one of the people I think it is not fair to
ask more of, you already do a lot. I have spoken to my management and my
team that we intend to hire external support for our foss4g stack if and
when our service scales.
     I tried to give the list participants a small nudge to reply to the
questions. The other alternative I thought of for the answers to catch
up with the questions was to encourage people to spend at least an hour
trying to solve the problem before e-mailing the list (which I did).
That would, however, probably go the other way around. I wouldn't feel
very welcome if someone asked me that.
     Thanks for the pointers on where to get the information. I checked
the github page and found the main committers to the jdbcconfig module.
pom.xml does not list maintainers, but has a lot of committers.
Best,
Daniel
Forensics Expert
Em 11/07/2016 18:32, Jody Garnett escreveu:
released as part of GeoServer. We set up the "community module" idea
- if the community module is not actively maintained ask on the email
- If the community module is actively maintained review the pom.xml
functionality that is *just* out of reach. We find this less
Jody Garnett
<mailto:miranda.dam@anonymised.com>> wrote:
    Hi everyone!
    geoserver
    please chime in.
    --Daniel
    > Hi, everyone.
    > I am trying to download the JDBCConfig module for
    installation in
    > my new geoserver 2.9 server, and I cannot find the file for
    download.
    > Here is what I tried:
    > -Read the docs at
    > -Went to http://geoserver.org/release/stable/ and clicked on
    > "extensions", and searched for the
    > geoserver-2.9.0-jdbcconfig-plugin.zip. That seemed to me to be
    the right
    > place, because there were zipfiles with the names of a lot of other
    > extensions.
    > -Did the same above for geoserver 2.8.4, found a lot of
    extensions, but
    > not this one.
    > -Searched again for the related module JDBCStore, also could not
    find it.
    > -Googled for geoserver-2.9.0-jdbcconfig-plugin.zip with no success
    > -Checked the release notes for geoserver 2.9.0 at
    > http://blog.geoserver.org/2016/05/30/geoserver-2-9-0-released/
    > and found a mention of the JDBCConfig module under "Resource REST
    > API", which leads me to believe that it is currently supported.
    > -Found the source at
    > and tried to compile Geoserver from source (although that was
    also
    > motivated by a specific LDAP need of mine). Compiling from
    source proved
    > to be too much right now, I am not familiar with the codebase and
    > haven't programmed in java for a long time. I would like to keep
    > everything stock to make maintenance easier and documentation
    shorter.
    > Should the zipfile be available at the locations I looked?
    > Is that module current (I take it that it is since the latest
    commit was
    > 15 days ago)?
    > Is it necessary to compile the module from source?
    > I apologize if I have missed something obvious. Please point me
    in the
    > right direction.
    > Best,
    > Daniel Miranda
    in San
    luminaries
    something for
    <mailto:Geoserver-users@lists.sourceforge.net>
