[Geoserver-users] installation on tomcat - An error occurred while saving the user: org.xml.sax.SAXParseException; Premature end of file.
I am trying to install/setup geoserver on my Ubuntu saucy server, using Tomcat 7.
I am using the war files and they seem to deploy fine - I have tried with the stable, the file geoserver-2.5.x-latest as well as the latest nightly master.
It seems to deploy fine, and I can access the web interface, and log in to the admin using the default password.
But - when I try to change the password for the "admin" login, I get a red bar on the top "An error occurred while saving the user: org.xml.sax.SAXParseException; Premature end of file."
When I check the geoserver/data/security/usergroup/default folder I can see that the users.xml has turned in to a zero byte file.
I can also see that the tomcat7 user has full access to all the files, so I doubt that it is a permissions problem (after all, since tomcat deployed the war, it created these files).
If I restart tomcat at this stage, then geoserver fails to load, and there is nothing obvious related to the failure in the log.
Any tips?
Thanks!
Below is what I found in geoserver.log for when I save.
2014-05-19 19:19:54,775 INFO [geoserver.security] - Start reloading user/grous for service named default
2014-05-19 19:19:54,779 INFO [geoserver.security] - Reloading user/groups successful for service named default
2014-05-19 19:21:23,077 INFO [geoserver.security] - Strong cryptography is available
2014-05-19 19:21:38,987 INFO [security.xml] - Successful lock: /var/www/amapgeonetwork/geoserver/data/security/usergroup/default/users.xml.lock
2014-05-19 19:21:39,052 INFO [geoserver.security] - Start storing user/grous for service named default
2014-05-19 19:21:39,245 INFO [geoserver.security] - Storing user/grous successful for service named default
2014-05-19 19:21:39,245 INFO [geoserver.security] - Start reloading user/grous for service named default
2014-05-19 19:21:39,247 WARN [geoserver.web] - org.xml.sax.SAXParseException; Premature end of file.
java.io.IOException: org.xml.sax.SAXParseException; Premature end of file.
  at org.geoserver.security.xml.XMLUserGroupService.deserialize(XMLUserGroupService.java:149)
  at org.geoserver.security.impl.AbstractUserGroupService.load(AbstractUserGroupService.java:152)
  at org.geoserver.security.impl.AbstractUserGroupStore.store(AbstractUserGroupStore.java:316)
  at org.geoserver.security.xml.XMLUserGroupStore.store(XMLUserGroupStore.java:223)
  at org.geoserver.security.concurrent.LockingUserGroupStore.store(LockingUserGroupStore.java:130)
  at org.geoserver.security.validation.UserGroupStoreValidationWrapper.store(UserGroupStoreValidationWrapper.java:98)
  at org.geoserver.security.web.user.EditUserPage.onFormSubmit(EditUserPage.java:52)
  at org.geoserver.security.web.user.AbstractUserPage$6.onSubmit(AbstractUserPage.java:194)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:958)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
  at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
  at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
  at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
  at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
  at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
  at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200)
  at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
  at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
  at java.lang.Thread.run(Thread.java:744)
Caused by: org.xml.sax.SAXParseException; Premature end of file.
  at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
  at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
  at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:121)
  at org.geoserver.security.xml.XMLUserGroupService.deserialize(XMLUserGroupService.java:147)
  ... 113 more
2014-05-19 19:21:39,249 ERROR [geoserver.web] - Error occurred while saving user
  ... 113 more
2014-05-19 19:21:44,757 INFO [geoserver.security] - Start reloading user/grous for service named default
Hugo Ahlenius
Hugo Ahlenius E-Mail: hugo.ahlenius(at)nordpil.com
                         Phone: +46 75 7575284
Nordpil Mobile: +46 733 467111
http://nordpil.com Skype: callto:hugo.ahlenius
                         Twitter: https://twitter.com/nordpil
       vCard: http://nordpil.com/hugoahlenius.vcf
