I am trying to install geoserver to Centos 6.3 cloud server. I have tried all combinations of tomcat6/war file and the jetty os independant installer. All crashing. See example. Please help.
Jim
[root@anonymised.com bin]# ./startup.sh
GEOSERVER DATA DIR is /usr/local/geoserver-2.1.2/data_dir
1 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
598 [main] WARN org.mortbay.log - Deprecated configuration used for /usr/local/geoserver-2.1.2/webapps
701 [main] INFO org.mortbay.log - jetty-6.1.8
(.:4412): Gtk-WARNING **: cannot open display:
James B. White
Cary, NC
H: 919-380-9615
M: 919-698-1765
White Coding and Maps
Please ensure that you are running the JVM in headless mode (so that it won’t attempt to connect to a display.) The simplest way to do this is to add ‘-Djava.awt.headless=true’ to your java command-line arguments. For the standalone installer you can do this by editing the startup script, otherwise please consult the centos documentation for tomcat.
On Sun, Dec 23, 2012 at 8:39 PM, Jim White <jbw2003@anonymised.com> wrote:
Jim
James B. White
Cary, NC
H: 919-380-9615
M: 919-698-1765
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
Thanks David. I have installed opengeo community edition and thats working. However, I might create another server and see how this works.
Jim
Jim
James B. White
Cary, NC
H: 919-380-9615
M: 919-698-1765
