Dear All
I have just started an installation of GeoServer on Linux (Fedora Core
4) and I have followed the instructions 'Install' at:
http://docs.codehaus.org/display/GEOSDOC/Install
I have got everything to work but there were some points that I didn't
understand/get to work as I would have liked. I think/hope they are
pretty simple for those in the know, so if anybody is able to help, I
would be very grateful.
1. I created the following environmental variables:
$ export JAVA_HOME=/usr/java/jdk1.5.0_07
$ export GEOSERVER_HOME=/usr/local/geoserver
$ export GEOSERVER_DATA_DIR=/usr/local/geoserver/data_dir
However I am finding that I need to recreate the variables each time
that I want to use geoserver. I have looked on the internet and it
suggests that 'export' only creates a temporary variable. Is this true,
and if so, how do I create a permanent variable?
2. I used the download: geoserver-*-bin.tar.gz. This has automatically
installed jetty for me. However I already have apache on my machine.
Could I have installed the geoserver to reference the apache I already
had on my machine, and if so, would I have had to install a servlet
container?
3. When I start geoserver through the terminal with the following
commands:
$ su – root
$ /usr/local/geoserver/bin/startup.sh
I find that the terminal window locks up. The only way I can shut the
window is by using the cross in the top right hand corner and this then
stops geoserver running. Do I just need to leave the terminal window
like this? And if so, do I need to run the shutdown.sh from another
terminal window?
Many Thanks
John
Manchester, UK
___________________________________________________________
All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
http://uk.docs.yahoo.com/nowyoucan.html
