PATH=C:\libjpeg-turbo\bin;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\ArcGIS\ArcSDE\ora10gexe\bin;C:\Apps\php;C:\Perl\site\bin;C:\Perl\bin;C:\Program Files\AMD APP\bin\x86;C:\Program Files\ImageMagick-6.6.0-Q8;C:\oracle\product\10.2.0\client_1\bin;C:\Program Files\Intel\DMIX;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Roxio Shared\DLLShared;C:\Program Files\Common Files\Roxio Shared\10.0\DLLShared;C:\Program Files\ArcGIS\Desktop10.1\Bin;C:\Program Files\PostgreSQL\9.2\bin;C:\Program Files\Windows Live\Shared;C:\Python27;C:\OSGeo4W\bin;C:\Program Files\GDAL;C:\Program Files\FME;C:\Program Files\ArcGIS\Desktop10.2\Bin;C:\Program Files\ArcGIS\EsriProductionMapping\Desktop10.2\Bin;C:\Program Files\Nmap
-Djava.util.logging.config.file=C:\Apps\apache-tomcat-7.0.47_1\conf\logging.properties
Hi Ross,
can you show your PATH and java.library.path values?
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Mon, Jan 13, 2014 at 3:00 PM, McDonaldR <McDonaldR@anonymised.com> wrote:
Thanks Daniele
I have updated the PATH env var to point to the \bin folder.
I have updated the JVM parameters to reference the jpeg62.dll
I have restarted the Tomcat services.
Still not available to Geoserver L
Folder PATH listing for volume OS
C:.
| uninstall_1.3.0.exe
±–bin
| cjpeg.exe
| djpeg.exe
| jpeg62.dll
| jpegtran.exe
| rdjpgcom.exe
| tjbench.exe
| wrjpgcom.exe
±–classes
| turbojpeg.jar
±–doc
| example.c
| libjpeg.txt
| README
| README-turbo.txt
| structure.txt
| usage.txt
| wizard.txt
±–include
| jconfig.h
| jerror.h
| jmorecfg.h
| jpeglib.h
| turbojpeg.h
-–lib
jpeg-static.lib
jpeg.lib
turbojpeg-static.lib
turbojpeg.lib
From: dany.geotools@anonymised.com…84… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: 13 January 2014 13:28
To: McDonaldR
Subject: Re: [Geoserver-users] Installing libjpeg-turbo on Windows GeoServer cluster
Can you list the content of C:\libjpeg-turbo?
I’m wondering whether the DLLs are on C:\libjpeg-turbo\bin. In that case you have to put that full path on your PATH vars, instead of the parent.
Please, let me know.
Daniele
On Mon, Jan 13, 2014 at 2:08 PM, McDonaldR <McDonaldR@anonymised.com> wrote:
Hi Daniele
Yes, turbojpeg.dll is in C:\Windows\system32
Thanks
Ross
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: 13 January 2014 13:05
To: McDonaldR
Cc: geoserver-users@anonymised.comrge.net
Hi Ross,
Could you check if you also have a turbojpeg.dll on your c:\windows\system32 folder?
Best Regards,
Daniele
On Mon, Jan 13, 2014 at 1:24 PM, McDonaldR <McDonaldR@anonymised.com> wrote:
Hi List
I am having difficulty in getting my Geoserver 2.4.3 cluster to recognise the libjpeg-turbo installation.
Following these instructions http://docs.geoserver.org/stable/en/user/community/libjpeg-turbo/index.html I have installed libjpeg-turbo to C:\libjpeg-turbo (version 1.3.0)
I have added C:\libjpeg-turbo to the start of my PATH system environment variable and added -Djava.library.path= C:\libjpeg-turbo to my Tomcat7 JVMs.
Each Geoserver instance has the correct libjpeg-turbo extension (community latest) installed.
As some background I have three Tomcat7 containers each running an instance of geoserver with Apache configured as a load balancer in front.
Restarting the Tomcat services and checking the logs I get the following:
“WARN [turbojpeg.TurboJPEGMapResponse] - The turbo jpeg encoder is not available, check the native libs installation”
Any help much appreciated.
Thanks
Ross
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-users mailing list
