[Geoserver-users] Installing WPS extension in GeoServer 2.5.1 on Tomcat 7: problems
Hi all!
I’m trying to install WPS extension in my GeoServer 2.5.1 on Tomcat 7.0.54 (Windows 7), but it doesn’t work.
I’ve following these steps:
  1. downloaded GeoServer 2.5.1 war and put in in Tomcat:it works fine
  2. dowloaded thw WPS extension following the link strating from here http://geoserver.org/release/2.5.1/
  3. stop tomcat
  4. put the WPS extension new jar files in my Tomcat WEB-INF/lib directory
  5. restart Tomcat
  6. try http://:8181/geoserver/ nut the result is … 404 Error.
Here you’re the log … .
2014-06-05 16:58:38,097 WARN [imagemosaic.Utils] - Unable to find sample image for path D:\Programmi\GeoServer223\data_dir\coverages\mosaic_sample\sample_image
2014-06-05 16:58:38,097 WARN [gce.imagemosaic] - Unable to find sample image for path file:/D:/Programmi/GeoServer223/data_dir/coverages/mosaic_sample/mosaic.shp
2014-06-05 16:58:39,295 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2014-06-05 16:58:39,297 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-gwc-2.5.1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘dispatcher’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘dispatcher’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘workspaceLocal’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1083)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1880)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘dispatcher’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘workspaceLocal’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
… 31 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘workspaceLocal’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Cannot resolve reference to bean ‘geoServer’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:202)
at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:140)
at org.geoserver.ows.Dispatcher.initApplicationContext(Dispatcher.java:193)
at org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:73)
at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:117)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:92)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
… 37 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [jar:file:/D:/Programmi/apache-tomcat-7.0.54/webapps/geoserver/WEB-INF/lib/gs-main-2.5.1.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
… 58 more
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:135)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:58)
… 64 more
Caused by: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.loadServices(GeoServerLoader.java:724)
at org.geoserver.config.GeoServerLoader.readConfiguration(GeoServerLoader.java:649)
at org.geoserver.config.DefaultGeoServerLoader.loadGeoServer(DefaultGeoServerLoader.java:72)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:129)
… 68 more
Any suggestions?
Thank you very much in advance
Cesare Gerbino
http://cesaregerbino.wordpress.com/
http://www.facebook.com/cesare.gerbino
http://www.facebook.com/pages/Cesare-Gerbino-GIS-Blog/246234455498174?ref=hl
https://twitter.com/CesareGerbino
http://www.linkedin.com/pub/cesare-gerbino/56/494/77b
It looks like the WPS download link was wrong - and was instead pointing to the WCS2.0 Earth Observation bundle!
So to get your GeoServer to work again … perhaps install WCS 2.0?
I have fixed the website now, if you spot any other links that are broken (or download the wrong thing) please let us know.
Jody Garnett
On Fri, Jun 6, 2014 at 1:13 AM, cesare gerbino <cesaregerbino@anonymised.com> wrote:
Hi all!
  3. stop tomcat
  5. restart Tomcat
… 31 more
… 37 more
… 58 more
… 64 more
… 68 more
Any suggestions?
Cesare Gerbino
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Geoserver-users mailing list
On Sat, Jun 7, 2014 at 6:10 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
So to get your GeoServer to work again ... perhaps install WCS 2.0?
WCS 2.0 is part of core in the 2.5.x series, so it is already there.
Unfortunately the exception does not help assessing where the problem is,
it's actually masking it,
something that I've fixed recently:
http://jira.codehaus.org/browse/GEOS-6504
Long story short, one of the wms/wfs/wcs.xml files in the root directory
fails to load, and due to
the bug in GEOS-6504 the startup sequence fails and the real error is never
written out.
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
