Andrea Aime-4 wrote:
Strange, just tries this one against the usual topp:states:
http://geo.openplans.org:8080/geoserver/wfs?service=WFS&version=1.0.0&request=GetFeature&typeName=topp:states&cql_filter=INTERSECT(the_geom,POINT(-95%2037))
and it works? That is a 1.7.2, also tried against a local 1.7.3 and it
works as well.
Thanks for your response. I tried the wfs request on topp:states on my local
server and it works fine so it looks like its a problem with my uploaded
map. I am using version 1.7.3. It seems strange that the other attributes
are recognised in the wfs requests and not the_geom. Is there anything in
the feature-type that might be causing this?
<featureType>
<name>united_kingdom_natural</name>
<nativeName>united_kingdom_natural</nativeName>
<namespace>
<name>SCAMBS</name>
<atom:link rel="alternate"
href="http://localhost:8080/geoserver/rest/namespaces/SCAMBS.xml"
type="application/xml"/>
</namespace>
<nativeCRS>
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Longitude", EAST],
AXIS["Latitude", NORTH],
AUTHORITY["EPSG","4326"]]
</nativeCRS>
<srs>EPSG:4326</srs>
<nativeBoundingBox>
<minx>-8.18125</minx>
<maxx>33.8149309</maxx>
<miny>34.5957938</miny>
<maxy>60.8018961</maxy>
<crs>EPSG:4326</crs>
</nativeBoundingBox>
<latLonBoundingBox>
<minx>-9.18125</minx>
</latLonBoundingBox>
<projectionPolicy>FORCE_DECLARED</projectionPolicy>
<enabled>true</enabled>
<metadata>
<indexingEnabled>
<boolean>false</boolean>
</indexingEnabled>
<cachingEnabled>
</cachingEnabled>
<gml.schemaSchema>
<string>united_kingdom_natural_Type</string>
</gml.schemaSchema>
<dirName>
<string>Natural_united_kingdom_natural</string>
</dirName>
<kml.regionateFeatureLimit>
<int>-1</int>
</kml.regionateFeatureLimit>
</metadata>
<store class="dataStore">
<name>Natural</name>
href="http://localhost:8080/geoserver/rest/workspaces/SCAMBS/datastoresNatural.xml"
</store>
<attributes>
<attribute>
<name>the_geom</name>
<minOccurs>0</minOccurs>
<maxOccurs>1</maxOccurs>
<nillable>false</nillable>
</attribute>
<attribute>
<name>NAME</name>
</attribute>
<attribute>
<name>TYPE</name>
</attribute>
</attributes>
<maxFeatures>0</maxFeatures>
<numDecimals>0</numDecimals>
</featureType>
View this message in context: http://www.nabble.com/INTERSECT-CQL_FILTER-in-feature-request-tp23171719p23173329.html
