[Geoserver-users] Invalid address error
It works for me and obviously for most other people because otherwise we would have received some mail about the issue.
Tell a bit more about your installation. Which OS, which jre, Jetty or Tomcat, how installed, which browser? You can’t even delete layer “top:states” from the admin utility?
-Jukka Rahkonen-
Eric DUCOS wrote:
Please tell me If I am alone to have this problem. What is the workaround ?
When I try to delete a workspace or a layer or some other item in GeoServer 2.5.1, 2.5.2 or 2.6RC, I am redirected to a page http:/// that says “Invalid address”.
How can I solve this problem ?
Regards.
Eric.
Ok,
GeoServer is installed as standalone on Windows Server 2012 using jetty integrated server.
The most easy installation that I can do. I run setup, and give really standard default answer to the different steps of installation process.
The JRE used is the Java 8 release 20
The Internet Explorer version is which is supplied with Windows Server 2012 or Windows 8.1, that is version 11
GeoServer is working fine……but…
When I login to the geoserver portal on the server(http://localhost:8080/geoserver), goes to the workspace management page, I get a list of demo workspaces that are installed by default. I want to clean up and delete all these workspaces.
I select all workspaces and click on “delete link” on top of the page.
In the normal process, a “window” opens that tell me to confirm the deletion (I already saw this windows in previous installation of geoserver)…but in this case, I am redirected to a page whose url is http:/// that contains the “invalid address” error message
I tried to add localhost to “compatibility list” of IE, and now is is working….but now, if I try to add a new workspace, the page is displayed with buttons not set in the correct place on the page…when I tried to update a layer, when I click on the Save button, nothing happens, we stay on the page and does not go back to the list of layers…
So according to the action I want to do (“delete an item” or “adding or updating an item”), I have or not to put localhost in the compatibility list of IE…I just think that it is not a production way to manage geoserver items…
I cannot deploy such product for end-users in such situation…
Please help me solve this problem…
Eric.
De : Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@anonymised.com86…]
Envoyé : jeudi 2 octobre 2014 09:43
À : ‘geoserver-users@lists.sourceforge.net’
Objet : Re: [Geoserver-users] Invalid address error
-Jukka Rahkonen-
Eric DUCOS wrote:
Regards.
Eric.
On Thu, Oct 2, 2014 at 10:12 AM, Eric DUCOS <Eric.DUCOS@anonymised.com> wrote:
Ok,
integrated server.
GeoServer is working fine…..but…
items…
Please help me solve this problem..
Try to use Firefox or Chrome, none of the GeoServer developers uses IE
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
