Are you going to deploy Geoserver to end users so that they will install it to their own computers to localhost? It can well be that the issue with IE affects only localhost address but if Geoserver is installed to an external address it may be that fiddling with compatibility list is not necessary.
I don’t have Windows 8 + IE 11 to test with, only Windows 7 and IE 9.
-Jukka Rahkonen-
Andrea Aime wrote:
On Thu, Oct 2, 2014 at 10:12 AM, Eric DUCOS <Eric.DUCOS@…6699…> wrote:
Ok,
GeoServer is installed as standalone on Windows Server 2012 using jetty integrated server.
The most easy installation that I can do. I run setup, and give really standard default answer to the different steps of installation process.
The JRE used is the Java 8 release 20
The Internet Explorer version is which is supplied with Windows Server 2012 or Windows 8.1, that is version 11
GeoServer is working fine……but…
When I login to the geoserver portal on the server(http://localhost:8080/geoserver), goes to the workspace management page, I get a list of demo workspaces that are installed by default. I want to clean up and delete all these workspaces.
I select all workspaces and click on “delete link” on top of the page.
In the normal process, a “window” opens that tell me to confirm the deletion (I already saw this windows in previous installation of geoserver)…but in this case, I am redirected to a page whose url is http:/// that contains the “invalid address” error message
I tried to add localhost to “compatibility list” of IE, and now is is working….but now, if I try to add a new workspace, the page is displayed with buttons not set in the correct place on the page…when I tried to update a layer, when I click on the Save button, nothing happens, we stay on the page and does not go back to the list of layers…
So according to the action I want to do (“delete an item” or “adding or updating an item”), I have or not to put localhost in the compatibility list of IE…I just think that it is not a production way to manage geoserver items…
I cannot deploy such product for end-users in such situation…
Please help me solve this problem…
Try to use Firefox or Chrome, none of the GeoServer developers uses IE
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
