Can please someone verfiy if shapefile export on geoserver 2.3.2 is still
working?
On each layer in Layer Preview with output format Shapefile-Export, I get a
403 bytes zip archive which is invalid. (GML, openlayers and JSON output
works)
Also the temporary dbf, prj and shx files in /var/cache/geoserver_home/temp
have size of 0kb
Here is my geotools-developer logging output:
2013-06-10 14:27:56,498 INFO [org.geoserver.wfs] -
Request: getServiceInfo
2013-06-10 14:27:56,500 INFO [org.geoserver.wfs] -
Request: getFeature
service = WFS
version = 1.0.0
baseUrl = http://localhost:8080/geoserver/
query[0]:
typeName[0] = {http://www.wien.gv.at/ogdwien\}WELTKULTERBEOGD
maxFeatures = 50
outputFormat = SHAPE-ZIP
resultType = results
2013-06-10 14:27:56,504 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2013-06-10 14:27:56,550 DEBUG [org.geotools.jdbc] - SELECT * FROM (SELECT
OBJECTID,SHAPE as SHAPE,NAME,TYP,BEZEICHNUNG,INFO,SE_ANNO_CAD_DATA FROM
MySchema.MYTable) WHERE ROWNUM <= 50
2013-06-10 14:27:56,565 DEBUG [org.geotools.data.shapefile] - Write lock:
file:/var/cache/adv-geoserver/temp/shpziptemp0.15797235458022774/WELTKULTERBEOGDPolygon.shp
by ShpFiles for deleting all files
2013-06-10 14:27:56,565 TRACE [org.geotools.data.shapefile] - SHP Channel in
ShapefileWriter has been opened. Number open: 1
2013-06-10 14:27:56,565 TRACE [org.geotools.data.shapefile] - SHX Channel in
2013-06-10 14:27:56,566 TRACE [org.geotools.data.shapefile] - SHP Channel in
ShapefileWriter has been closed. Number open: 0
2013-06-10 14:27:56,566 TRACE [org.geotools.data.shapefile] - SHX Channel in
2013-06-10 14:27:56,566 DEBUG [org.geotools.data.shapefile] - Field Length
for OBJECTID set to 33 Preserving length, but should be set to Max of 18 for
dbase III specification.
2013-06-10 14:27:56,566 WARN [org.geoserver.wfs.response] - Error while
writing featuretype 'WELTKULTERBEOGD' to shapefile.
java.io.IOException: Unable to write : [B
at
org.geotools.data.shapefile.ShapefileDataStore.createDbaseHeader(ShapefileDataStore.java:1217)
at
org.geotools.data.shapefile.ShapefileDataStore.createSchema(ShapefileDataStore.java:1003)
at
org.geoserver.wfs.response.ShapeZipOutputFormat.buildStore(ShapeZipOutputFormat.java:792)
at
org.geoserver.wfs.response.ShapeZipOutputFormat.getFeatureWriter(ShapeZipOutputFormat.java:703)
at
org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefiles(ShapeZipOutputFormat.java:625)
at
org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:235)
at
org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:208)
at
org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:190)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:46)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:103)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:555)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:662)
2013-06-10 14:27:56,567 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: java.io.IOException: Unable to
write : [B
at
org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefiles(ShapeZipOutputFormat.java:649)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.io.IOException: Unable to write : [B
at
at
at
at
at
... 80 more
2013-06-10 14:30:13,992 WARN [org.geotools.jdbc] - There is code leaving
feature readers/iterators open, this is leaking statements and connections!
2013-06-10 14:30:13,994 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2013-06-10 14:30:13,995 WARN [org.geotools.jdbc] - There is code leaving
2013-06-10 14:30:13,997 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2013-06-10 14:30:13,998 WARN [org.geotools.jdbc] - There is code leaving
2013-06-10 14:30:13,999 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
View this message in context: http://osgeo-org.1560.x6.nabble.com/invalid-shapefile-archive-tp5059110.html
