Having a bit of a problem getting Geoserver to pick up a GeoTIFF from under the coverages dir. "Invalid url: ‘file:coverages/spam_glc2.tiff’ for format type:‘GeoTIFF’.
I’m running this on a Linux system with Tomcat and I’m not totally sure what the “Invalid URL” means. It doesn’t appear tp be a problem with finding the file, as when I change the path specification in the “New CoverageStore” interface, I get a true “File not Found” error. The file is located in, “/usr/local/apache-tomcat-6.0.16/webapps/geoserver/data/coverages/”
Can anyone advise me as to what things I should check?
The GeoTiff “looks” like this in gdalinfo:
$ gdalinfo spam_glc2.tif
Driver: GTiff/GeoTIFF
Size is 2403, 1584
Coordinate System is `’
Origin = (-197.922038228547677,147.448452606569646)
Pixel Size = (0.164802963691709,-0.164802963691709)
Corner Coordinates:
Upper Left ( -197.922, 147.448)
Lower Left ( -197.922, -113.599)
Upper Right ( 198.099, 147.448)
Lower Right ( 198.099, -113.599)
Center ( 0.0887226, 16.9245054)
Band 1 Block=2403x3 Type=Byte, ColorInterp=Red
Band 2 Block=2403x3 Type=Byte, ColorInterp=Green
Band 3 Block=2403x3 Type=Byte, ColorInterp=Blue
Band 4 Block=2403x3 Type=Byte, ColorInterp=Alpha
Roger
Roger André
GIS Developer/Analyst
Enterprise Management Solutions
CH2M HILL
1100 112th Avenue NE
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
roger.andre@anonymised.com
Developing People through Challenging Projects
Is that tiff, or tif?
Size is 2403, 1584
Corner Coordinates:
Roger
Roger André
CH2M HILL
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Sorry, it’s .tiff on the server. I thought it might not have been picking the file up because it was “.tif”, instead of “.tiff”, so I tested it with both names.
No dice.
From: geoserver-users-bounces@lists.sourceforge.net [mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Eric Engle
Sent: Wednesday, March 19, 2008 1:36 PM
Subject: Re: [Geoserver-users] “Invalid url” error for new coverage store
Size is 2403, 1584
Corner Coordinates:
Roger
Roger André
CH2M HILL
Suite 400
Bellevue, WA 98004
Direct 425.233.3042
Geoserver-users@anonymised.comts.sourceforge.net
Roger.Andre@anonymised.com ha scritto:
Having a bit of a problem getting Geoserver to pick up a GeoTIFF from under the coverages dir. "Invalid url: 'file:coverages/spam_glc2.tiff' for format type:'GeoTIFF'.
I'm running this on a Linux system with Tomcat and I'm not totally sure what the "Invalid URL" means. It doesn't appear tp be a problem with finding the file, as when I change the path specification in the "New CoverageStore" interface, I get a true "File not Found" error. The file is located in, "/usr/local/apache-tomcat-6.0.16/webapps/geoserver/data/coverages/"
The GeoTiff "looks" like this in gdalinfo:
Size is 2403, 1584
Coordinate System is `'
This is the reason, no CRS. GeoServer does not consider it a valid
coverage for this reason. You can use gdal_traslate -a_srs to force
an SRS into the file.
Perfect, thanks very much! Easy fix, and makes sense. Related to that,
if I used a file that had an attached worldfile and a .prj, would
GeoServer pick it up? It's not what I intend to do here, but I had
thought of using georeferenced PNG's in the future.
-----Original Message-----
Sent: Wednesday, March 19, 2008 1:54 PM
To: Andre, Roger/SEA
Subject: Re: [Geoserver-users] "Invalid url" error for new coverage
store
Size is 2403, 1584
coverage for this reason. You can use gdal_traslate -a_srs to force an
SRS into the file.
You can specify the full path to your .tiff file:
file:/usr/local/apache-tomcat-6.0.16/webapps/geoserver/data/coverages/spam_glc2.tiff
Alex
On Wed, Mar 19, 2008 at 2:50 PM, <Roger.Andre@...598...> wrote:
Sorry, it's .tiff on the server. I thought it might not have been picking
the file up because it was ".tif", instead of ".tiff", so I tested it with
both names.
No dice.
Engle
Subject: Re: [Geoserver-users] "Invalid url" error for new coverage store
located in,
> Size is 2403, 1584
> Corner Coordinates:
> Thanks,
> Roger
> Roger André
> CH2M HILL
> Suite 400
> Bellevue, WA 98004
> Direct 425.233.3042
> roger.andre@...598...
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Ciao Andre,
Yeah, but using the world image format (yet
) the geotiff format.
I would not use intensively PNG since java support for this format is
quite poor.
Best option is geotiff with internal overviews.
Simone.
store
> Size is 2403, 1584
SRS into the file.
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
