Hello Simone,
It’s kind of you to answer.
First, I wanted to create my own mosaic with personal tiff tiles.
I did it with the gdaltindex tool.
Once I had my shp tile index file, I launched the geoserver mosaick plugin in the coveragestore but it failed.
It returned me the same error message: “invalid url (…) for format type:‘ImageMosaic’.”
I wondered if it was because my properties file was correct or not…
I told to myself: why not trying with the demo mosaic.shp which is already provided with geoserver?
I went to the coveragestore and clicked “edit” with the mosaic.shp which was already present.
It gave me the error message written in this message. But does the mosaic.shp need the image-io extension as it indexes PNG files (it think so, at least)?
At the moment i performed that, my jdk version was the 1.6 and when i set up my geoserver before, it automatically retrieved the 1.6 jdk folder…Consequently, I think that there was no need to configure a JAVA_HOME variable…
So, with the advice of arne, i downgraded to the 1.5 but I still got the same error message.
I tried displaying the mosaic.shp at home on my Mac OS Computer and all worked properly although i hadn’t configured anything…
I think that the fact even the mosaic.shp doesn’t work on my windows XP platform is not normal. I also tried on a 2003 server platform. I may have missed something. I thought everything should have worked automatically for the mosaic.shp file…
Thanks again to look into my problem,
Mathieu
Date: Thu, 4 Jun 2009 23:22:24 +0200
Subject: Re: [Geoserver-users] "Invalid url: ‘file:coverages/mosaic_sample/mosaic.shp’ for format type:‘ImageMosaic’.
To: baobazz@anonymised.com
CC: geoserver-users@anonymised.comsourceforge.net
Ciao Mathieu,
please read below…
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Jun 3, 2009 at 9:53 AM, mathieu rajerison baobazz@anonymised.com wrote:
Hello,
I’m a beginner with GeoServer
I’ve got the 1.7.4 Geoserver version.
I had real fun with it and managed to display some feature types.
Now, I’m interested in rasters. I’m trying to get a coverage store but it
doesn’t work. I tried with the demo data: mosaic.shp, already configured.
When I push the edit button, i get the following error message:
type:‘ImageMosaic’.
Mmmhh, strange, going to check shortly.
I followed the steps mentionned in the web:
-I put a user environment variable JAVA_HOME which points to C:\Program
Files\Java\j2re1.4.2_06
-I downloaded the GDAL dlls from here
http://trac.osgeo.org/gdal/wiki/BuildingOnWindows
in particular:
http://download.osgeo.org/gdal/win32/1.4.1/gdalwin32exe141.zip
-I put them in my C:\Program Files\Java\j2re1.4.2_06\bin directory
So here are the all GDAL files i’ve got in that directory:
gdal14.dll
gdaladdo.exe
gdalconstjni.dll
gdalinfo.exe
gdaljni.dll
gdaltindex.exe
gdalwarp.exe
gdal_contour.exe
gdal_ECW_JP2ECW.dll
gdal_rasterize.exe
gdal_translate.exe
msvcp71.dll
msvcr71.dll
I restarted the server but it still doesn’t work.
Did I miss anything?
I didn’t install the Image-IO extension because i thought it was only
mandatory for formats which were not supported. Maybe I was wrong?
Installing GDAL itself is useless, GeoTools/GeoServer won’t use it
right away. If you need to support layers which are not supported by
GeoServer natively you need to install imageio-ext-gdal extensions.
So, my question is what is your goal?
Simone.
Help would be greatly appreciated. It’s been two days I’m trying to get that
functional…
Mat’
Souhaitez vous « être au bureau sans y être » ? Oui je le veux !
OpenSolaris 2009.06 is a cutting edge operating system for enterprises
looking to deploy the next generation of Solaris that includes the latest
innovations from Sun and the OpenSource community. Download a copy and
enjoy capabilities such as Networking, Storage and Virtualization.
Go to: http://p.sf.net/sfu/opensolaris-get
Geoserver-users mailing list
Vous voulez savoir ce que vous pouvez faire avec le nouveau Windows Live ? Lancez-vous !
