[Geoserver-users] invoking geoserver servlets from another web app
I am new to geoserver and have basic servlet
knowledge my question is:
Can I build a web application e.g a couple of servlets
archived in war file
that gather map (wfs) request from a user, then invoke
the required
geoserver servlet to provide a response ? Put in
another way, is it possible for my servlet which is
archived in a separate war file to invoke a geoserver
since geoserver is archived in a separate war file ?
How can I do this.
Thanks in advance
Roman
      ____________________________________________________________________________________
Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
Roman Isitua ha scritto:
archived in war file that gather map (wfs) request from a user, then invoke
the required
another way, is it possible for my servlet which is archived in a separate war file to invoke a geoserver
How can I do this.
Sure you can, invoking WFS from java code is dealt with in the FAQ:
http://docs.codehaus.org/display/GEOSDOC/How+do+I+make+a+WFS+request+in+my+JSP-Java+code
http://docs.codehaus.org/display/GEOSDOC/My+WFS+request+in+Java+does+not+work.
All you have to do is to read the response and return it back to your
client. Also the code in https://svn.codehaus.org/geoserver/trunk/geoserver/wfs/src/main/java/org/vfny/geoserver/wfs/servlets/TestWfsPost.java
can be of inspiration, since this servlet exactly takes a form with
some request as a parameter, calls WFS/WMS/WCS and the returns the
response to the client.
Hi Roman,
Do you need direct access to the servlets running inside of geoserver... or can you just go through the wfs protocol. Ie. make a wfs request just like a normal client would.
-Justin
Roman Isitua wrote:
the required
How can I do this.
Thanks in advance
Roman
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,469b366a257732085621377!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi justin,
Yes, I think I need direct access. I was told that I
can use a request dispatcher. Can I have sample code
on how to do this. how can I pass the shapefile and
the OGC filter using the request dispatcher. Thanks
Roman
--- Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Roman,
-Justin
Roman Isitua wrote:
> Hi,
servlets
invoke
> the required
is
geoserver
> How can I do this.
> Thanks in advance
> Roman
express and take
to get it now.
> Geoserver-users@lists.sourceforge.net
Justin Deoliveira
Don't get soaked. Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Pinpoint customers who are looking for what you sell.
http://searchmarketing.yahoo.com/
Hi Roman,
Well I think the links that Andrea sent out are the only way to do this... You cant really get access to the servlets running in geoserver... everything is through http. The closest thing might be an RPC or remoting interface... but GeoServer is not currently set up like that today.
-Justin
Roman Isitua wrote:
Hi justin,
Roman
Hi Roman,
-Justin
Roman Isitua wrote:
servlets
invoke
the required
is
geoserver
How can I do this.
Thanks in advance
Roman
express and take
to get it now.
Justin Deoliveira
Pinpoint customers who are looking for what you sell. http://searchmarketing.yahoo.com/
!DSPAM:4007,469c8ad3263991804284693!
Justin Deoliveira
