[Geoserver-users] Is anonymous binding required for ldap authentication?
Hi list!
We are setting up authentication against an LDAP server. When we test the connection we recieve the following error:
javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C0903A9, comment: AcceptSecurityContext error, data 52e, v1db1]
Could the reason be that anonymous binding is required? I’m not sure if this is the case in GeoServer. In our environment anonymous binding is not allowed.
We use Geoserver 2.2-SNAPSHOT/Windows Server 2008/Tomcat 7. The server is not inside the AD.
Thanks in advance.
All best,
Andreas
Hi Andreas
The developer of the ldap plugin is in holidays for 3 weeks. I will try to help here.
If you dont want an anonymous login, remove the "anonymous" filter from all filter chains. This can be done using the "Authentication" panel in the top security menu.
I googled the LDAP error code, 49 seems to be "invalid credentials". Did you test your ldap connection without using Geoserver ?
Christian
Zitat von Andreas Fogelberg <andreas20@anonymised.com>:
Hi list!
v1db1]
Could the reason be that anonymous binding is required? I'm not sure if
allowed.
not inside the AD.
Thanks in advance.
All best,
Andreas
This message was sent using IMP, the Internet Messaging Program.
Thank you Christian!
Removing the “anonymous” filter did help me to solve the problem. I also had to change the settings for User loopkup pattern from uid ={0} to cn={0}.
What I didn’t manage to do is a recursive search in the LDAP database. For those users I still get the same error:
v1db1]
Kind regards,
Andreas
2012/12/12 <christian.mueller@anonymised.com>
Hi Andreas
If you dont want an anonymous login, remove the “anonymous” filter from all filter chains. This can be done using the “Authentication” panel in the top security menu.
I googled the LDAP error code, 49 seems to be “invalid credentials”. Did you test your ldap connection without using Geoserver ?
Christian
Hi list!
v1db1]
allowed.
not inside the AD.
Thanks in advance.
All best,
Andreas
Hi Andreas
I am not used to using LDAP, what do you mean with a recursive search ? AFAIK, the LDAP plugin does a simple bind with username/credentials, so I have no idea about your problem.
Christian
Removing the "anonymous" filter did help me to solve the problem. I also
What I didn't manage to do is a recursive search in the LDAP database. For
javax.naming.**AuthenticationException: [LDAP: error code 49 - 80090308:
v1db1]
Kind regards,
Andreas
Hi Andreas
help here.
top security menu.
Christian
Hi list!
v1db1]
allowed.
not inside the AD.
Thanks in advance.
All best,
Andreas
Hi!
By recursive I mean that I would like to do a subtree search. In our case users are defined in subtrees.
Andreas
Hi Andreas
Christian
v1db1]
Kind regards,
Andreas
Hi Andreas
help here.
top security menu.
Christian
Hi list!
v1db1]
allowed.
not inside the AD.
Thanks in advance.
All best,
Andreas
Hi Andreas
I think I cannot help further and we have to wait for Justin returning from holidays (3 weeks).
I would estimate 10 hours of work which I have not. (Setting up test environment, studying the code, looking at your concrete situation,...).
Christian
Hi!
Andreas
Hi Andreas
Christian
cn={0}.
javax.naming.****AuthenticationException: [LDAP: error code 49 -
80090308:
v1db1]
Kind regards,
Andreas
Hi Andreas
to
help here.
the
top security menu.
Christian
Hi list!
the
80090308:
v1db1]
not
allowed.
is
not inside the AD.
Thanks in advance.
All best,
Andreas
Thanks anyway. Meanwhile, if I find a solution I will report back.
Andreas
2012/12/13 <christian.mueller@anonymised.com>
Hi Andreas
I would estimate 10 hours of work which I have not. (Setting up test environment, studying the code, looking at your concrete situation,…).
Christian
Hi!
Andreas
Hi Andreas
Christian
cn={0}.
80090308:
v1db1]
Kind regards,
Andreas
Hi Andreas
to
help here.
the
top security menu.
Christian
Hi list!
the
80090308:
v1db1]
not
allowed.
is
not inside the AD.
Thanks in advance.
All best,
Andreas
