On Sat, Nov 22, 2014 at 6:02 PM, Roger Bedell <sylvanascent@anonymised.com>
wrote:
Hi Niels,
Thanks for this answer. I guess what I am really asking is if it is
possible to extend the list of properties in the ResourceInfo object? Then
associate this with a metadata field as described.
A simple example would be to add a text property named "purpose".
I tried adding this to the featuretype.xml file for a layer, but it just
disappears the next time I save the layer information from GeoServer.
One cannot add top level fields, but you can add new items in the metadata
map.
You might have already have some entries in there, and can add more:
<metadata>
<entry key="cacheAgeMax">3600</entry>
<entry key="kml.regionateFeatureLimit">10</entry>
<entry key="indexingEnabled">false</entry>
<entry key="cachingEnabled">true</entry>
<entry key="dirName">DS_giant_polygon_giant_polygon</entry>
</metadata>
The metadata map is a flat key/value pair, string key, string value, so you
cannot easily
put complex elements into it (to be precise, one could, we store the sql
views definitions
in the for example, but that requires some extra java programming to
support it)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
