To a newbie GeoServer looks to be very complex, for my needs is there
something easier or less intimitating to use ?
I need to generate a static image ( jpeg, tiff, png, etc ) of the
United States once a month.
I would provide data like:
CT 10
NY 100
CA 150
TX 500
The map would outline all the states.
values of 0-99 would be green - CT
values of 100-499 would be blue - NY, CA
values 500-up would be red. - TX
Is GeoTools better suited for this purpose, or perhaps an API that
sits on top of GeoTools ?
Any help is appreciated.
-Thanks
Steve More
Hi Stephen,
If you need to publish the image then I think GeoServer is the way to go
hands down. If you just need to generate the image then I guess you
could use geotools rendering directly, but you would have to write code
to do it. And I am sad to say that things like this arent all that well
documented, although hoping on IRC or the geotools mailing list someone
wile provide you with a code sample.
Either way I think you would be better off using GeoServer. It is fairly
straight forward to congfigure your data. And it supports SLD which you
can use to style your map the way you outlined. Plus you get a wide
variety of output formats: png, jpeg, gif, kml, georss, etc...
If you have any more questions please dont hesitate to ask.
-Justin
CT 10
NY 100
CA 150
TX 500
-Thanks
Steve More
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,467be399277421804284693!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Ok.
The population example is very close to what I need:
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&Format=image/png&request=GetMap&layers=topp:states&width=750&height=375&srs=EPSG:4326
I have installed the mysql plugin such that the following works:
http://localhost:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.0.0&typename=topp:geoserver_test
1. For my example data below, what needs to be inserted into the MySQL
geoserver_test table ?
2. Once I have the data, do I just add my data layer and create a new
style ? Perhaps I could copy the current population style as a
template ?
layers=topp:states,topp:geoserver_test&styles=mystyle1
-Steve More
> CT 10
> NY 100
> CA 150
> TX 500
> -Thanks
> Steve More
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
Ok.
So are you wanting to use the states data as a base? Like start with it
and add your attribute to it? geoserver wont really do any joining or
anything so you might have to create a table for the states data, then
supplement it with your attribute.
I am not all that familiar with mysql. Is there a utility for converting
a shapefile to sql for a mysql spatial table? I know there is one for
postgres called shp2pgsql.
template ?
Yup, but i think you will probably have to it with a single layer. The
population style from geoserver can be a good start.
-Steve More
CT 10
NY 100
CA 150
TX 500
-Thanks
Steve More
Justin Deoliveira
!DSPAM:4007,467bfdd8316382092453641!
Justin Deoliveira
As an experienced MapServer and ArcIMS user, let me tell you that GeoServer is incredibly simple. Geoserver adheres to well documented standards, and for you case, I think a simple SLD in combination with a view from your database might work.
I do not know what the database structure of your database system is, but we perform similar tasks by marking certain columns as “most recent”. If you do this in the context of a view, and expose this view to Geoserver, as you make updates to your database, the maps will change in accordance with your data. It would seem that you have relatively simple class breaks, which should be able to be represented in the form of a view. I am not so familiar with MySQL, but this is quite strightforward in Postgres and should work in a similar fashion with MySQL.
Thanks for all your help.
I have decided to use geotools directly.
I created a servlet that
creates a org.geotools.styling.Style
creates a org.geotools.map.MapContext using that style
then I output the mapContext using
org.geotools.renderer.lite.StreamingRenderer.
I guess now I just need to learn alot more about SLD.
-Steve More
perform similar tasks by marking certain columns as "most recent". If you
