[Geoserver-users] Is there a way to change geowebcache naming convention to store tiles in z/y/x format on disk?
Is there a way to change geowebcache naming convention to store tiles in z/y/x format on disk? I would prefer not to fool around with FilePathGenerator.java.
Do you have any idea?
Best regards
On Mon, Apr 20, 2015 at 5:16 PM, <stoffel@anonymised.com> wrote:
As another option, you'd have to plug-in a different BlobStore, which you'd
have to write.
Cleaner, more work than just fooling around FilePathGenerator
Mind, the z/y/x approach will work fine only on small pyramids, and/or on
selected file systems (ones that can handle millions
of files in a single directory, a single row of tiles, worldwide map,
should be around a million files at zoom level 20)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
