I made a test with Geoserver 2.8 milestone version on Windows, with Jetty and cascading by using https and basic authentication works fine with our servers. I could also publish without troubles the Fires24 layer from
because the site does not seem to require username/password.
I think that the "Remote host closed connection during handshake" may come from some general network things and not from Geoserver. Java version may have some influence. I have a 1.8.0_40 (32-bit).
Thanks for answering.
No, I'm not using any proxy. As a matter of fact, as it didn't work on my server (using old geoserver 2.5.2), I checked locally on my computer, with latest stable geoserver release (2.7.1). Doesn't work either.
So no proxy. Geoserver 2.7.1. And I tried both : connection pooling or not; doesn't change anything, same error message.
Tél. : (+33) 6 09 23 21 36
Hi Jean,
wondering, are you going through a proxy to access that server?
Also, did you try switching the wms cascading store from the connection pooling one,
to the non pooling configuration?
Finally, which version of GeoServer are you using?
On Wed, Jun 3, 2015 at 4:14 PM, Jean Pommier
<jean.pommier@anonymised.com <mailto:jean.pommier@anonymised.com>> wrote:
Hi List,
A cascaded WMS service stopped working when the remote WMS
source switched from http to https. Is there a trouble with
cascading https WMS sources ?
The source is MODIS fires :
https://firms.modaps.eosdis.nasa.gov/wms/?SERVICE=WMS&VERSION=1.1.1&REQUEST=GETCAPABILITIES
When trying to setup a new datastore using this URL, I get the
following error :
"Le test de connexion a echoué : Remote host closed connection
during handshake".
I've search for answers, but found none. Any idea, someone ?
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. :
(+33) 6 09 23 21 36 <tel:%28%2B33%29%206%2009%2023%2021%2036>
E-mail : jp@anonymised.com <mailto:jp@anonymised.com>
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
Geoserver-users mailing list
<mailto:Geoserver-users@lists.sourceforge.net>
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare
il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June,
30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the
named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability
as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
