[Geoserver-users] Is use of the Marlin renderer recommended
I thought it might do that. In text form for point 2:
- I put the *.jar reference in the Java Classpath of the w.exe Java tab and then added:
-Dsun.java2d.renderer=org.marlin.pisces.PiscesRenderingEngine
-Dsun.java2d.renderer.useThreadLocal=false
to the Java Options.
However, I don't think I've seen a reference to Marlin in the GeoServer logs so I wonder if I've put the *.jar reference in the wrong place?
Paul
Message: 1
Date: Mon, 8 Aug 2016 09:52:17 +0000
Subject: [Geoserver-users] Is use of the Marlin renderer recommended
To: "geoserver-users@lists.sourceforge.net"
        <geoserver-users@lists.sourceforge.net>
Message-ID:
        <D67B8B2041F8004B9C0534736661A4D1FB444AAB@anonymised.com>
Content-Type: text/plain; charset="us-ascii"
I have found a blog post from 2014 suggesting that there is an improved renderer for Oracle available. This appears to be the Marlin Renderer and I have attempted to follow the installation instructions; however I'm never quite certain how that fits with the Tomcat service deployment. Two questions:
1) Is it recommended to use Marlin still (I'm using GeoServer 2.8.4)?
2) Is this the correct place to put the settings (hopefully there will be a screenshot below:
[cid:image001.png@anonymised.com]
Paul
"This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation."
Type: image/png
Desc: image001.png
Geoserver-users mailing list
End of Geoserver-users Digest, Vol 123, Issue 17
Hi Paul,
you can verify the renderer GeoServer is using by checking the "Java Rendering Engine" on the "Server Status" screen (the first link in web admin GUI). If you use Marlin, you'll have "org.marlin.pisces.PiscesRenderingEngine" in there.
Peter
Paul
Message: 1
Message-ID:
Paul
Type: image/png
Desc: image001.png
Peter Kovac
IMS Programmer
MicroStep-MIS
peter.kovac@anonymised.com
