[Geoserver-users] Issue with geoserver layer style change using PHP curl
Geoserver rest api change layer style using PHP curl is not working
I have tried using this code and nothing happed.
Please can any one help on this.
Thank you in advance.
     curl_setopt($this->ch, CURLOPT_POST, True);
        $passwordStr = "admindd:geoservdder";
        curl_setopt($this->ch, CURLOPT_USERPWD, $passwordStr);
curl_setopt($this->ch, CURLOPT_CUSTOMREQUEST, 'PUT'); // -X
curl_setopt($this->ch, CURLOPT_HTTPHEADER, ['Content-Type: text/xml']); //
-H
$post =
array("<layer><defaultStyle><name>polygon</name></defaultStyle></layer>");
curl_setopt($this->ch, CURLOPT_POSTFIELDS, $post);
buffer = curl_exec($this->ch);
View this message in context: http://osgeo-org.1560.x6.nabble.com/Issue-with-geoserver-layer-style-change-using-PHP-curl-tp5156790.html
