After some more experimenting, it seems that the issue also affects small
datasets. (but for small datasets, GoogleEarth doesn't get overwhelmed...)
From looking at GeoServer's request.log, it appears that when using
GoogleEarth's "After Camera Stops" view-based refresh, the GetMap requests
sometimes fire continuously. An example request.log is shown below, showing
that GoogleEarth is firing 20 GetMap requests per second. This log was
generated after panning GoogleEarth so the features were not visible on the
screen, pausing until the network link refreshes, then panning back toward
the features.
So far I have only been able to trigger this rapid fire of GetMap requests
to occur by performing the following actions while using the "After Camera
Stops" refresh mode :
1. Navigate in GE to the region where the data are. Wait for the Network
Link to refresh.
(GE fires a single GetMap request)
2. Navigate to a region where there are no features. Wait for the Network
Link to refresh.
3. Start GE panning across the landscape (i.e. click and drag/throw)
(while the features are not in the view, GE fires GetMap requests
continuously)
(once the features are back in view, GE stops firing GetMap requests)
Any suggestions on how to deal with this issue (since it causes GE to throw
an error for larger datasets)?
My guess is that this is a bug in GoogleEarth, but maybe there is another
reason for this behavior. Does anyone have contacts with GE developers,
with whom we might communicate this issue?
- Tyler
198.111.191.175 - - [26/06/2007:13:09:42 +0000] "GET
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.200326167291,59.90490336671706,-143.6438037173544,60.15383272811881
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1988410196415,59.90498461561302,-143.6423282644629,60.15390781761896
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1973821797538,59.90506440884716,-143.6408789482003,60.15398156043942
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1959011252179,59.90514540048818,-143.6394075629189,60.15405640940681
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1944357085867,59.90522552045422,-143.6379517140502,60.15413045143195
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.193002941873,59.90530383944203,-143.6365283025056,60.15420282777651
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1915468639609,59.90538341659651,-143.6350817325582,60.15427636547834
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1900980943828,59.90546257824248,-143.6336424238094,60.15434951786249
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1886574924387,59.90554127768458,-143.6322112299385,60.15442224179981
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1871112677542,59.90562572958729,-143.6306751037565,60.15450027994861
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1856818538676,59.90570378523545,-143.629255026066,60.15457240625155
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1842543398123,59.90578172154295,-143.6278368363668,60.15464442097597
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1828241186144,59.90585979001823,-143.6264159577775,60.15471655651967
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1813644809523,59.90593944805664,-143.6249658554688,60.15479015947675
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1798773166801,59.90602059156847,-143.6234884069836,60.15486513359007
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1784169118966,59.90610025855181,-143.6220375437649,60.15493874205966
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1769886023806,59.90617815891795,-143.6206185666944,60.15501071693994
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1755291164776,59.90625774353462,-143.6191686175279,60.1550842466099
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1740921109135,59.90633608639911,-143.6177410023872,60.15515662767061
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1726607203788,59.90641410744183,-143.6163189661554,60.15522871008572
HTTP/1.1" 200 149
198.111.191.175 - - [26/06/2007:13:09:43 +0000] "GET
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1712098714233,59.90649317311713,-143.6148775992489,60.15530175628179
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1697455621321,59.90657295600539,-143.6134228605719,60.15537546372076
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.168322907151,59.90665045365321,-143.612009504528,60.15544705862456
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1668644595198,59.90672988500061,-143.6105605903721,60.15552043859842
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1648651536088,59.906838746646,-143.6085743543434,60.15562100454674
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1634170904731,59.90691757418865,-143.6071357581959,60.15569382351264
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1624600474551,59.90696966349495,-143.6061849723494,60.15574194160865
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1610069808241,59.90704873665658,-143.6047414063931,60.15581498522884
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1595328917596,59.90712893732087,-143.6032769560568,60.1558890689932
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1579433981966,59.90721539817061,-143.6016978565039,60.15596893391749
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1564612741921,59.90729600122281,-143.6002254250333,60.15604338646375
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1550182774068,59.90737446026193,-143.5987918654929,60.15611585724417
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1535881713166,59.90745220269434,-143.5973711129144,60.15618766479332
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1521289160065,59.90753151359545,-143.595921402352,60.15626091972062
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1501788529542,59.90763747460395,-143.593984095266,60.15635878768856
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1492096640847,59.90769012681704,-143.5930212465552,60.15640741754702
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1477527528004,59.90776926155353,-143.5915738664637,60.1564805056671
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1462926755003,59.90784855197429,-143.590123341662,60.15655373620795
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1448333768192,59.90792778382374,-143.5886735909787,60.15662691128534
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1433558534716,59.90800798858213,-143.587205735475,60.15670098350474
HTTP/1.1" 200 149
198.111.191.175 - - [26/06/2007:13:09:44 +0000] "GET
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1418865724486,59.90808772936732,-143.5857460689672,60.15677462583547
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1404237006335,59.90816710591345,-143.5842927703249,60.1568479304049
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1389685148458,59.9082460491759,-143.5828471080035,60.15692083346993
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1375382428959,59.90832362509474,-143.581426197046,60.15699247248411
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1356194853899,59.90842764662131,-143.579511832389,60.15708853115112
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1345869666078,59.90848360089392,-143.5784783615205,60.15714020113835
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1330485924968,59.90856695337864,-143.5769385693761,60.15721717025043
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1316128438543,59.90864472907975,-143.5755014978404,60.15728898829205
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1301543182164,59.90872372250544,-143.5740416288591,60.15736192942236
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1285768493639,59.90880913957633,-143.5724627077219,60.15744080049242
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1271181208104,59.90888811015902,-143.5710026367639,60.15751371768085
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1256880920054,59.90896551125673,-143.5695712924905,60.15758518436194
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1242298490325,59.90904442337485,-143.5681117086307,60.15765804485658
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1227826036916,59.90912272430077,-143.5666631330498,60.15773033967661
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1213363176392,59.90920095734211,-143.565215518171,60.15780257047177
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1198783239748,59.90927980750314,-143.5637561854616,60.15787536967596
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1184478926133,59.90935715127925,-143.562324440894,60.15794677676438
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1170165702001,59.9094345275906,-143.5608918049771,60.15801821257114
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1155555343748,59.90951349404917,-143.5594294289178,60.15809111508124
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1141242147178,59.9095908385892,-143.557996796812,60.15816251888808
HTTP/1.1" 200 149
198.111.191.175 - - [26/06/2007:13:09:45 +0000] "GET
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.11268497029,59.90966859558317,-143.5565562331939,60.1582343021371
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1107447266814,59.90977339464722,-143.55461421202,60.15833104781299
HTTP/1.1" 200 149
/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&BBOX=-144.1093130814141,59.90985070417325,-143.5531812557562,60.15840241485506
HTTP/1.1" 200 3912
Tyler Erickson wrote:
I also haven't been able to reproduce the issue with small datasets.
When I request a raster image (output=kmz&KMSCORE=1) GoogleEarth gives me
the same Fetch error, but the log messages are different...
INFO | jvm 1 | 2007/06/22 17:51:33 | 3464983 [INFO]
org.vfny.geoserver.wms.requests.GetMapKvpReader - Set KMScore: 1
org.vfny.geoserver.servlets.AbstractService - handling request:
INFO | jvm 1 | 2007/06/22 17:51:33 | GetMap Request
INFO | jvm 1 | 2007/06/22 17:51:33 | version: 1.1.1
INFO | jvm 1 | 2007/06/22 17:51:33 | output format: kmz
INFO | jvm 1 | 2007/06/22 17:51:33 | width height: 375,800
INFO | jvm 1 | 2007/06/22 17:51:33 | bbox: Env[-143.7529664744341 :
-143.3268421685196, 59.99926299466871 : 60.21867765839906]
INFO | jvm 1 | 2007/06/22 17:51:33 | layers:
INFO | jvm 1 | 2007/06/22 17:51:33 | styles: measurement_ph
org.geotools.arcsde.data.ArcSDEDataStore - getCount
INFO | jvm 1 | 2007/06/22 17:51:34 | 3465983 [INFO]
org.geotools.arcsde.data.ArcSDEQuery - No FID attribute was contained in
your query. Appending the discovered one to the list of columns to be
fetched.
INFO | jvm 1 | 2007/06/22 17:51:34 | 3466092 [INFO]
org.vfny.geoserver.servlets.AbstractService - Service handled
Brent Owens wrote:
hmm, interesting. I am using GeoServer and Google Earth right now and
I can't reproduce the issue. But I am also returning much fewer
features (around 100), so maybe it is the sheer number of features
being returned and google earth can't handle it? Does it change if you
have it return a raster image as KMZ? (output=kmz&KMSCORE=1)
From the logs it looks like google earth is dieing on the requests,
and just terminating them after a little while.
Has anyone else had this issue?
On 6/22/07, Tyler Erickson <tyler.erickson@anonymised.com> wrote:
I am having an issue with a Google Earth network link (refresh option
'After
Camera Stops') that is accessing the KML output of GeoServer. Geoserver
is
drawing from an ArcSDE data source of point features. The link fails to
return data under certain conditions.
Here is the set of actions that causes the issue:
Network
Link to refresh.
Network
Link to refresh.
3. Navigate back to the region where the data are. Wait for the Network
Link to refresh.
Actions 1 and 2 seem to work fine (no strange log messages), but Action
3
causes Google Earth to return an error 'Fetch of NetworkLink "pH"
failed'
(and causes a host of log messages, see end of message).
Additional notes:
- I can't seem to generate the same issue when I use the 'Refresh on
request' option of the network link.
- around 2200 features should be returned
- I running the GeoServer 1.5.x nightly build from 6/21/2007 and the
ArcSDE
9.2 plugin
My GoogleEarth network link is defined as:
<kml xmlns="http://earth.google.com/kml/2.1">
<NetworkLink>
<name>pH</name>
<visibility>0</visibility>
<Url>
<href>http://gisdev:8080/geoserver/wms?styles=&Format=kml&request=GetMap&layers=mtri:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH&width=800&height=375&srs=EPSG:4326&</href>
<viewRefreshMode>onStop</viewRefreshMode>
<viewRefreshTime>2</viewRefreshTime>
</Url>
</NetworkLink>
</kml>
The log starts with seemingly normal messages about successful
requests...
INFO | jvm 1 | 2007/06/22 16:29:08 | 1034701 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:08 | GetMap Request
INFO | jvm 1 | 2007/06/22 16:29:08 | version: 1.1.1
INFO | jvm 1 | 2007/06/22 16:29:08 | output format: kml
INFO | jvm 1 | 2007/06/22 16:29:08 | width height: 375,800
INFO | jvm 1 | 2007/06/22 16:29:08 | bbox: Env[-143.8355934905155
-143.1498949847171, 59.92165451535668 : 60.27407239091361]
INFO | jvm 1 | 2007/06/22 16:29:08 | layers:
INFO | jvm 1 | 2007/06/22 16:29:08 | styles: measurement_ph
INFO | jvm 1 | 2007/06/22 16:29:10 | 1035951 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:22 | 1048732 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:22 | GetMap Request
INFO | jvm 1 | 2007/06/22 16:29:22 | version: 1.1.1
INFO | jvm 1 | 2007/06/22 16:29:22 | output format: kml
INFO | jvm 1 | 2007/06/22 16:29:22 | width height: 375,800
INFO | jvm 1 | 2007/06/22 16:29:22 | bbox: Env[-146.1372014712449
-145.4329027467601, 59.85406315579387 : 60.21739754554545]
INFO | jvm 1 | 2007/06/22 16:29:22 | layers:
INFO | jvm 1 | 2007/06/22 16:29:22 | styles: measurement_ph
INFO | jvm 1 | 2007/06/22 16:29:22 | 1048748 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054451 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | GetMap Request
INFO | jvm 1 | 2007/06/22 16:29:28 | version: 1.1.1
INFO | jvm 1 | 2007/06/22 16:29:28 | output format: kml
INFO | jvm 1 | 2007/06/22 16:29:28 | width height: 375,800
INFO | jvm 1 | 2007/06/22 16:29:28 | bbox: Env[-146.1296697007228
-145.425445472396, 59.85420853698207 : 60.21750576945373]
INFO | jvm 1 | 2007/06/22 16:29:28 | layers:
INFO | jvm 1 | 2007/06/22 16:29:28 | styles: measurement_ph
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054466 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054513 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | bbox: Env[-146.0732961045507
-145.3696062310459, 59.85640662847004 : 60.21942554613189]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054529 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | bbox: Env[-146.0326797972647
-145.3293848111581, 59.85754057990144 : 60.22035883395015]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054544 [INFO]
org.vfny.geoserver.servlets.AbstractService - Stream abruptly closed by
client, response aborted
org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer - aborting KML
encoder
org.vfny.geoserver.servlets.PartialBufferStrategy2 - OutputStream was
successfully aborted.
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054576 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | bbox: Env[-145.9319643009186
-145.2296309222599, 59.86124298849921 : 60.22356302381956]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054591 [INFO]
The log file then repeats for around 100 GetMap Requests of the
following
form:
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054607 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:28 | bbox: Env[-145.8874717249382
-145.1856054749774, 59.86090433663627 : 60.22300411802691]
INFO | jvm 1 | 2007/06/22 16:29:28 | 1054623 [INFO]
and finally starts throwing WARNINGs about the client closing the
stream:
INFO | jvm 1 | 2007/06/22 16:29:32 | 1058747 [INFO]
INFO | jvm 1 | 2007/06/22 16:29:32 | GetMap Request
INFO | jvm 1 | 2007/06/22 16:29:32 | version: 1.1.1
INFO | jvm 1 | 2007/06/22 16:29:32 | output format: kml
INFO | jvm 1 | 2007/06/22 16:29:32 | width height: 375,800
INFO | jvm 1 | 2007/06/22 16:29:32 | bbox: Env[-143.7555566347445
-143.070143501927, 59.90788343040273 : 60.26057772104673]
INFO | jvm 1 | 2007/06/22 16:29:32 | layers:
INFO | jvm 1 | 2007/06/22 16:29:32 | styles: measurement_ph
INFO | jvm 1 | 2007/06/22 16:29:36 | 1062216 [INFO]
encoder
INFO | jvm 1 | 2007/06/22 16:29:37 | Jun 22, 2007 4:29:37 PM
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator
encode
INFO | jvm 1 | 2007/06/22 16:29:37 | WARNING: Failure tranforming
feature to KML:SDE_NRCS.DBO.V_MEASUREMENT_SPATIAL_PH.2365
INFO | jvm 1 | 2007/06/22 16:29:37 | java.lang.RuntimeException:
org.mortbay.jetty.EofException
INFO | jvm 1 | 2007/06/22 16:29:37 | at
org.geotools.xml.transform.TransformerBase$TranslatorSupport.chars(TransformerBase.java:462)
org.geotools.xml.transform.TransformerBase$TranslatorSupport.cdata(TransformerBase.java:481)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodePlacemarkDescription(KMLVectorTransformer.java:641)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encodePlacemark(KMLVectorTransformer.java:547)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:232)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:205)
org.vfny.geoserver.wms.responses.map.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:186)
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:187)
org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:110)
org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:625)
org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:293)
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:126)
org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)
org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:106)
org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:496)
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:582)
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
org.mortbay.jetty.Server.handle(Server.java:269)
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:687)
org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:492)
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
INFO | jvm 1 | 2007/06/22 16:29:37 | Caused by:
org.apache.xml.serializer.ToStream.cdata(ToStream.java:1246)
org.apache.xml.serializer.ToStream.characters(ToStream.java:1351)
org.apache.xalan.transformer.TransformerIdentityImpl.characters(TransformerIdentityImpl.java:1125)
org.geotools.xml.transform.TransformerBase$TranslatorSupport.chars(TransformerBase.java:460)
INFO | jvm 1 | 2007/06/22 16:29:37 | ... 45 more
View this message in context:
http://www.nabble.com/Issue-with-GoogleEarth-NetworkLinks-that-refresh-'After-Camera-Stops'-tf3966961.html#a11260038
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
Brent Owens
View this message in context: http://www.nabble.com/Issue-with-GoogleEarth-NetworkLinks-that-refresh-'After-Camera-Stops'-tf3966961.html#a11307477
