On Thu, Jul 30, 2015 at 7:56 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
We have the following GeoServer setup:
Datastore to an Oracle 12c Exadata instance
Internal connection pooling
No schema specified
What GEoServer version?
We noticed a serious performance anomaly, where each layer was taking
about 4 s to render, even when the data was very small.
When we switched to specifying an explicit schema in the Datastore config,
the performance got significantly faster, and the time to render individual
layers became more proportional to the query result size.
So the questions are:
1. does omitting a schema name in the Oracle Datastore config cause
connection pooling to be disabled or defeated?
While I cannot ensure I won't be hit by an asteroid in the next hour,
that's unlikely. So is the idea that not setting
up the catalog can break connection pooling.
It will likely slow down things for other reasons unrelated to connection
pooling instead.
Oracle is a database from hell, if you don't setup the catalog the jdbc
driver returns a huge number of tables (50k on some installations?) when
you get the
database metadata.
We had issues with caching metadata at the content data store level, with
the Oracle dialect not using prepared statements
for metadata (pull request still open, I'm unable to find the time to
review it, see here:
https://github.com/geotools/geotools/pull/905), and likely something else
that I don't remember.
I would suggest to try trunk, with the above pull request applied, and see
if it gets any better.
2. Will this issue be avoided when using a JNDI connection pool?
Not directly, but with JNDI you can setup a single connection pool and then
setup N datastores, one for each
of the catalogs you need to access.
Investigations and patches welcomed too, we have a large disconnect between
people using and complaining
about Oracle and people actually doing something about it. The common
wisdom is to just drop
Oracle in favor of PostGIS, when one can (yes, I'm well aware that's often
not an option).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
