What really happens when you run gdalinfo is that it tries to capture a small image for further investigations.
The request is
GET /geoserver/wcs?SERVICE=WCS&VERSION=1.1.0&REQUEST=GetCoverage&IDENTIFIER=raster_example_20130208_113005_078&FORMAT=image%2Ftiff%3Bsubtype%3D%22geotiff%22&BOUNDINGBOX=-116.917,32.41666843,-116.75033333,32.5833351,urn:ogc:def:crs:EPSG::4326&RangeSubset=contents HTTP/1.1
Host: 193.175.162.189
Accept: */*
Accept-Encoding: gzip
Proxy-Connection: Keep-Alive
Geoserver does not like the request and it sends an error message which is
<ows:ExceptionReport version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://193.175.162.189:80/geoserver/schemas/ows/1.1.0/owsAll.xsd"
xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.IllegalArgumentException: The specified dimensional parameter is non-positive.
The specified dimensional parameter is non-positive.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Reason for the failure seems to be in BOUNDINGBOX=-116.917,32.41666843,-116.75033333,32.5833351,urn:ogc:def:crs:EPSG::4326
Reverse the lon-lat coordinates into lat-lon, and the request works.
If Geoserver folks will tell that the GDAL WCS 1.1.0 request is wrong then you can try to get an answer to question b) by sending a question with this information into GDAL developer mailing list.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Robert Kulawik [mailto:rob-news@anonymised.com]
Lähetetty: 8. helmikuuta 2013 13:29
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Issue with noValue in WCS coverageOfferingsHi List,
i have a problem with noValue (or nullValue) entrys in Geoserver's WCS and i
don't found a solution for it yet.I store a rasterfile, format ArcGrid, GeoTIFF and/or ErdasImg to Geoserver,
version 2.2.x, via REST interface and edit the coverage.xml to add some
missed entrys. So i expand among other the dimensions_node with a range
and novalue informations corresponding to the raster values, like:<dimensions>
<coverageDimension>
<name>GRAY_INDEX</name>
<description>GridSampleDimension[-Infinity,Infinity]</description>
<range>
<min>0.0</min>
<max>100.0</max>
</range>
<nullValues>
<double>129.0</double>
</nullValues>
</coverageDimension>
</dimensions>My coverages are requested by a application using GDAL (v1.9.1). GDAL
reads the coverageOfferings (describeCoverage request) to get the raster
informations and compute something exluding the noValue regions in the
raster.The issue ist now, when GDAL read the coverageOfferings in WCS 1.0.0, the
novalue (or nullValue) entrys are not delivered by Geoserver and GDAL can't
use it:
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&coverag
e=raster_example_20130208_113005_078&VERSION=1.0.0in WCS 1.1.0 and 1.1.1 Geoserver delivers the noValues,
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifie
rs=raster_example_20130208_113005_078&VERSION=1.1.0
rs=raster_example_20130208_113005_078&VERSION=1.1.1but GDAL can't use the 1.1.x version of WCS, when i specify the WCS version
to 1.1.x , e.g.
<WCS_GDAL>
<ServiceURL>http://193.175.162.189/geoserver/wcs?</ServiceURL><CoverageName>raster_example_20130208_113005_078</CoverageName>
<Version>1.1.0</Version>
</WCS_GDAL>GDAL can read the coverage offering with included novalues but cant open it:
C:\OSGeo4W\bin>gdalinfo wcs.xml
ERROR 1: java.lang.IllegalArgumentException: The specified dimensional
gdalinfo failed - unable to open 'wcs.xml'.Has someone a solution how i can
a) deliver novalues using the WCS 1.0.0 version in Geoserver or
b) teach GDAL to use Gerserver's WCS 1.1.xMany thanks in advance
Robert------------------------------------------------------------------------------
Free Next-Gen Firewall Hardware Offer
Buy your Sophos next-gen firewall before the end March 2013 and get the
hardware for free! Learn more.
http://p.sf.net/sfu/sophos-d2d-feb
Geoserver-users mailing list
