One more thing. Document http://www.gdal.org/frmt_wcs.html says:
NoDataValue: The nodata value to use for all the bands (blank for none). Normally defaulted from CoverageOffering info.
Try to add your NoDataValue into the GDAL WCS configuration XML for the WCS 1.0.0.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Rahkonen Jukka [mailto:jukka.rahkonen@anonymised.com]
Lähetetty: 8. helmikuuta 2013 14:09
Vastaanottaja: 'rob-news@anonymised.com'; 'geoserver-users@anonymised.comet'
Aihe: Re: [Geoserver-users] Issue with noValue in WCS coverageOfferingsHi,
What really happens when you run gdalinfo is that it tries to capture a small
image for further investigations.
The request isGET
/geoserver/wcs?SERVICE=WCS&VERSION=1.1.0&REQUEST=GetCoverage&ID
ENTIFIER=raster_example_20130208_113005_078&FORMAT=image%2Ftiff%
3Bsubtype%3D%22geotiff%22&BOUNDINGBOX=-116.917,32.41666843,-
116.75033333,32.5833351,urn:ogc:def:crs:EPSG::4326&RangeSubset=content
s HTTP/1.1
Host: 193.175.162.189
Accept: */*
Accept-Encoding: gzip
Proxy-Connection: Keep-AliveGeoserver does not like the request and it sends an error message which is
<ows:ExceptionReport version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://193.175.162.189:80/geoserver/schemas/ows/1.1.0/owsAll.xsd"
xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.IllegalArgumentException: The specified
dimensional parameter is non-positive.
The specified dimensional parameter is non-positive.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>Reason for the failure seems to be in BOUNDINGBOX=-116.917,32.41666843,-
Reverse the lon-lat coordinates into lat-lon, and the request works.If Geoserver folks will tell that the GDAL WCS 1.1.0 request is wrong then you
can try to get an answer to question b) by sending a question with this
information into GDAL developer mailing list.-Jukka Rahkonen-
> Lähettäjä: Robert Kulawik [mailto:rob-news@anonymised.com]
> Lähetetty: 8. helmikuuta 2013 13:29
> Vastaanottaja: geoserver-users@lists.sourceforge.net
> Aihe: [Geoserver-users] Issue with noValue in WCS coverageOfferings
> Hi List,
> i have a problem with noValue (or nullValue) entrys in Geoserver's WCS
> and i don't found a solution for it yet.
> I store a rasterfile, format ArcGrid, GeoTIFF and/or ErdasImg to
> Geoserver, version 2.2.x, via REST interface and edit the coverage.xml
> to add some missed entrys. So i expand among other the
dimensions_node
> with a range and novalue informations corresponding to the raster values,
like:
> <dimensions>
> <coverageDimension>
> <name>GRAY_INDEX</name>
> <description>GridSampleDimension[-Infinity,Infinity]</description>
> <range>
> <min>0.0</min>
> <max>100.0</max>
> </range>
> <nullValues>
> <double>129.0</double>
> </nullValues>
> </coverageDimension>
> </dimensions>
> My coverages are requested by a application using GDAL (v1.9.1). GDAL
> reads the coverageOfferings (describeCoverage request) to get the
> raster informations and compute something exluding the noValue regions
> in the raster.
> The issue ist now, when GDAL read the coverageOfferings in WCS 1.0.0,
> the novalue (or nullValue) entrys are not delivered by Geoserver and
> GDAL can't use it:
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&coverag
> e=raster_example_20130208_113005_078&VERSION=1.0.0
> in WCS 1.1.0 and 1.1.1 Geoserver delivers the noValues,
http://193.175.162.189/geoserver/wcs?request=DescribeCoverage&identifi
> e
> rs=raster_example_20130208_113005_078&VERSION=1.1.0
> e
> rs=raster_example_20130208_113005_078&VERSION=1.1.1
> but GDAL can't use the 1.1.x version of WCS, when i specify the WCS
> version to 1.1.x , e.g.
> <WCS_GDAL>
> <ServiceURL>http://193.175.162.189/geoserver/wcs?</ServiceURL>
<CoverageName>raster_example_20130208_113005_078</CoverageName>
> <Version>1.1.0</Version>
> </WCS_GDAL>
> GDAL can read the coverage offering with included novalues but cant open
it:
> C:\OSGeo4W\bin>gdalinfo wcs.xml
> ERROR 1: java.lang.IllegalArgumentException: The specified dimensional
> gdalinfo failed - unable to open 'wcs.xml'.
> Has someone a solution how i can
> a) deliver novalues using the WCS 1.0.0 version in Geoserver or
> b) teach GDAL to use Gerserver's WCS 1.1.x
> Many thanks in advance
> Robert
> Free Next-Gen Firewall Hardware Offer
> Buy your Sophos next-gen firewall before the end March 2013 and get
> the hardware for free! Learn more.
> http://p.sf.net/sfu/sophos-d2d-feb
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users------------------------------------------------------------------------------
Buy your Sophos next-gen firewall before the end March 2013 and get the
