[Geoserver-users] Issues with png quality, geoserver 2.6
We are currently upgrading Geoserver from version 2.1 to 2.6, we have encountered problems with image quality.
Version 2.1 uses Oracle JDK 6 and version 2.6 uses OpenJDK 7. Both versions have native JAI and ImageIO installed.
If you compare the images from version 2.1 and version 2.6 you can clearly see that version 2.1 provides a much sharper image.
Geoserver version 2.1 GetLegendGraphic request (png). Geoserver version 2.6 GetLegendGraphic request (png).
The legend is in swedish from our quaternary deposits wms.
I would appreciate some help on how to solve this.
Jonas Holmberg
Geological Survey of Sweden
On Tue, Nov 18, 2014 at 9:55 AM, Jonas Holmberg <Jonas.Holmberg@anonymised.com>
wrote:
Java changed the way it renders things causing more than one issue, but
this could also be
a change in GeoServer, hard to say, you made a very long jump there.
I'd suggest to first use the Oracle JDK instead of OpenJDK, as the
rasterization engine is
different
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It looks like you may have anti-aliasing on in 2.6 when pulling these images. We’ve seen these issues with WMS tiles coming back.
http://docs.geoserver.org/stable/en/user/webadmin/services/WMS.html#svg-options
__________________________ (╯°□°)╯︵ ┻━┻
Ivan Suftin - Applications Developer - isuftin@anonymised.com
Office: (608) 821-3825 - Cell : (608) 345-8963
Center for Integrated Data Analytics - http://cida.usgs.gov/
United States Geological Survey
8505 Research Way, Middleton, WI 53562
On Nov 18, 2014, at 2:55 AM, Jonas Holmberg <Jonas.Holmberg@anonymised.com> wrote:
Jonas Holmberg
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=157005751&iu=/4140/ostg.clktrk_______________________________________________
Geoserver-users mailing list
