[Geoserver-users] JAI dependencies causing build, install and required for runtime failures
Attached is my maven install log
SEVERE: Unable to resolve feature source.
java.lang.AssertionError: java.lang.ClassNotFoundException: javax.media.jai.JAI
  at org.geotools.factory.Hints$Key.<init>(Hints.java:303)
  at org.geotools.factory.Hints.<clinit>(Hints.java:179)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Unknown Source)
  at org.geotools.factory.FactoryCreator.class$(FactoryCreator.java:60)
  at org.geotools.factory.FactoryCreator.<clinit>(FactoryCreator.java:60)
  at org.geotools.feature.FeatureTypeFactory.getServiceRegistry(FeatureTypeFactory.java:59)
  at org.geotools.feature.FeatureTypeFactory.newInstance(FeatureTypeFactory.java:235)
  at org.geotools.data.DataUtilities.createType(DataUtilities.java:962)
  at org.geotools.data.property.PropertyDataStore.getSchema(PropertyDataStore.java:51)
  at org.geotools.data.property.PropertyFeatureSource.<init>(PropertyFeatureSource.java:30)
  at org.geotools.data.property.PropertyDataStore.getFeatureSource(PropertyDataStore.java:92)
  at org.geotools.catalog.FeatureSourceGeoResource.featureSource(FeatureSourceGeoResource.java:285)
  at org.geotools.catalog.FeatureSourceGeoResource.resolve(FeatureSourceGeoResource.java:122)
  at org.geotools.catalog.property.PropertyGeoResource.resolve(PropertyGeoResource.java:41)
  at org.geoserver.data.GeoServerCatalogTest.testResolveResources(GeoServerCatalogTest.java:47)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.apache.maven.surefire.junit.JUnitTestSet.execute(JUnitTestSet.java:210)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:135)
  at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:122)
  at org.apache.maven.surefire.Surefire.run(Surefire.java:129)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:225)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:747)
Caused by: java.lang.ClassNotFoundException: javax.media.jai.JAI
  at java.net.URLClassLoader$1.run(Unknown Source)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.net.URLClassLoader.findClass(Unknown Source)
  at java.lang.ClassLoader.loadClass(Unknown Source)
  at org.apache.maven.surefire.booter.IsolatedClassLoader.loadClass(IsolatedClassLoader.java:100)
  at java.lang.ClassLoader.loadClassInternal(Unknown Source)
  at org.geotools.factory.Hints$Key.<init>(Hints.java:301)
  ... 41 more
[ERROR] BUILD FAILURE
log.txt (12.5 KB)
Yeh these crept in from the WCS branch. I am removing them at the moment and the next release won't contain the dependencies.
Thanks for finding this one.
Brent Owens
(The Open Planning Project)
    ... 41 more
[INFO] Scanning for projects...
[INFO] Reactor build order: [INFO] GeoServer
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Main Module
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] Web Application Module
[INFO] Artifact Merger PlugIn
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer
[INFO] task-segment: [install]
[INFO] [site:attach-descriptor]
[INFO] [install:install]
[INFO] Installing D:\projects\geoserver\1.4.x\pom.xml to C:\Documents and Settings\mrisney\.m2\repository\org\geoserver\geoserver\1.4.0-RC1\geoserver-1.4.0-RC1.pom
[INFO] Building Core Platform Module
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] Surefire report directory: D:\projects\geoserver\1.4.x\platform\target\surefire-reports
C:\DOCUME~1\mrisney\LOCALS~1\Temp
27-Oct-2006 19:52:34 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from file [D:\projects\geoserver\1.4.x\platform\target\test-classes\org\geoserver\applicationContext.xml]
27-Oct-2006 19:52:34 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 2 beans defined in application context [org.springframework.context.support.GenericApplicationContext;hashCode=1925270]
27-Oct-2006 19:52:35 org.springframework.core.CollectionFactory <clinit>
INFO: JDK 1.4+ collections available
INFO: Commons Collections 3.x available
27-Oct-2006 19:52:35 org.geoserver.BeanPersister loadBean
WARNING: Could not persistance file for bean: myBean
27-Oct-2006 19:52:35 org.springframework.context.support.AbstractApplicationContext initMessageSource
INFO: Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
27-Oct-2006 19:52:35 org.springframework.context.support.AbstractApplicationContext initApplicationEventMulticaster
INFO: Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
27-Oct-2006 19:52:35 org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in factory [org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [myBean,beanPersister]; root of BeanFactory hierarchy]
27-Oct-2006 19:52:35 org.springframework.context.support.AbstractApplicationContext close
INFO: Closing application context [org.springframework.context.support.GenericApplicationContext;hashCode=1925270]
27-Oct-2006 19:52:35 org.springframework.beans.factory.support.AbstractBeanFactory destroySingletons
INFO: Destroying singletons in factory {org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [myBean,beanPersister]; root of BeanFactory hierarchy}
27-Oct-2006 19:52:35 org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
27-Oct-2006 19:52:35 org.springframework.context.support.AbstractApplicationContext refresh
INFO: 2 beans defined in application context [org.springframework.context.support.GenericApplicationContext;hashCode=24669796]
INFO: Closing application context [org.springframework.context.support.GenericApplicationContext;hashCode=24669796]
INFO: 2 beans defined in application context [org.springframework.context.support.GenericApplicationContext;hashCode=16821027]
[INFO] [jar:jar]
[INFO] Building jar: D:\projects\geoserver\1.4.x\platform\target\platform-1.4.0-RC1.jar
[INFO] Installing D:\projects\geoserver\1.4.x\platform\target\platform-1.4.0-RC1.jar to C:\Documents and Settings\mrisney\.m2\repository\org\geoserver\platform\1.4.0-RC1\platform-1.4.0-RC1.jar
[INFO] Building Data Module
[INFO] Surefire report directory: D:\projects\geoserver\1.4.x\data\target\surefire-reports
27-Oct-2006 19:52:36 org.springframework.core.CollectionFactory <clinit>
27-Oct-2006 19:52:36 org.geotools.catalog.FeatureSourceGeoResource featureSource
  ... 41 more
[INFO] Total time: 5 seconds
[INFO] Finished at: Fri Oct 27 19:52:36 BST 2006
[INFO] Final Memory: 10M/18M
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Wait, I'm not sure that it's crept in from the WCS branch. I think it may be that the jars we had to handle this in 1.3.x didn't make it in to 1.4.x?
Brent Owens
    ... 41 more
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
  ... 41 more
!DSPAM:1003,454256f5176651971556521!
Chris Holmes
http://topp.openplans.org
I'm not sure it's actually needed though. I'm going to take a deeper look.
But if we can include the jar then that might be sufficient.
Brent Owens
Brent Owens
    ... 41 more
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
    ... 41 more
Yeh it looks like it has always used the jars. I will add them in so it will compile for people.
Brent Owens
Brent Owens
    ... 41 more
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
    ... 41 more
So we have resolved the issue for now I believe. Brent can build, Marc
can you verify?
-Justin
Justin Deoliveira
jdeolive@anonymised.com
just checked out revision 5387 ... no good ..make it better thx .. u guys rawk
can you verify?
-Justin
Justin Deoliveira
here is my build log, do dat vodoo dat only u can doo-doo
thx
> can you verify?
> -Justin
> Justin Deoliveira
build.log (4.59 KB)
Did it download the jars? Can you check to see if they're in your maven repository?
And was it the exact same error? Or something different?
can you verify?
-Justin
Justin Deoliveira
!DSPAM:1003,45427290193492207481331!
Chris Holmes
Whoops, my bad, should be fixed now. revision 5388
-Justin
repository?
guys rawk
can you verify?
-Justin
Justin Deoliveira
easier
Geronimo
!DSPAM:1004,45427340194391429667743!
Justin Deoliveira
