Can you see images from the WMS? If JAI isn't there and needed the
jpeg, gif and png images from the WMS won't work at all...
I dont think JAI is required by Geoserver at all. The only requirements
are with geotools -- martin uses a JAI class in the coordinate xform
stuff.
If you're using the GridCoverage stuff (ie. WCS branch), then you might
need JAI. I'm not sure.
I removed all the JAI image writers with new ones (that actually work).
dave
This mail sent through IMP: https://webmail.limegroup.com/
