[Geoserver-users] Japanese characters in WMS layer name
I wonder if non-English characters are supported in GeoServer WMS? I tried
to put some Japanese characters in the alias of a feature type (shape file
based) and it looks like the capabilities responses look good. But when I
actually request map none of the clients work, in which they all return
exception.
Any idea how I can get Japanese characters working in Geoserver?
Yingqi
View this message in context: http://www.nabble.com/Japanese-characters-in-WMS-layer-name-tp23972103p23972103.html
Yingqi ha scritto:
exception.
Which exception? Can you provide a full stack trace (enable "verbose
exceptions" in config/server)
Andrea Aime
OpenGeo - http://opengeo.org
Andrea,
Thanks for the response, it's not a Java exception but a WMS exception
saying:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1" > <ServiceException
code="LayerNotDefined">
      Could not find layer topp:???
</ServiceException></ServiceExceptionReport>
The Japanese characters are correct in GetCapabilities response though.
Here is the request I sent:
http://sazabi:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=日本語&amp;STYLES=polygon&amp;FORMAT=image/png&amp;BGCOLOR=0xFFFFFF&amp;TRANSPARENT=TRUE&amp;SRS=EPSG:4326&amp;BBOX=123\.661530852299,23\.6511065060158,148\.895080925309,46\.1305522937712&amp;WIDTH=1017&amp;HEIGHT=906
Also tried:
http://sazabi:8080/geoserver/wms?SERVICE=WMS&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=topp:日本語&amp;STYLES=polygon&amp;FORMAT=image/png&amp;BGCOLOR=0xFFFFFF&amp;TRANSPARENT=TRUE&amp;SRS=EPSG:4326&amp;BBOX=123\.661530852299,23\.6511065060158,148\.895080925309,46\.1305522937712&amp;WIDTH=1017&amp;HEIGHT=906
Thanks
Andrea Aime-4 wrote:
Yingqi ha scritto:
tried
file
exception.
Andrea Aime
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Japanese-characters-in-WMS-layer-name-tp23972103p23984615.html
Yingqi ha scritto:
Andrea,
saying:
Also tried:
My guess is that the url can only host ascii chars and that you should
url-encode the japanes chars, but I'm not sure.
Can you try out "%E6%97%A5%E6%9C%AC%E8%AA%9E" instead of "日本語"?
Andrea Aime
Andrea,
This works, and also I tried it in Firefox (I tested with IE first) which
works automatically. So I guess IE doesn't encode non-English in URL
correctly in UTF-8.
Thanks a lot!
Yingqi ha scritto:
Andrea,
saying:
Also tried:
Andrea Aime
View this message in context: http://www.nabble.com/Japanese-characters-in-WMS-layer-name-tp23972103p23985520.html
