[Geoserver-users] JAVA environment variable problem
Hi GeoServer users, I was trying to install Geoserver on Ubuntu Linux and I had a little problem:
My JAVA_HOME is defined, I know because when I type “echo $JAVA_HOME”, it says: /usr/local/bin/jdk1.6.0_06/bin/java
But when I try to run startup.sh I read this message: “The JAVA_HOME environment variable is not defined correctly
This environment variable is needed to run this program”
If any knows what could be happen please tell me.
Thanks in advance.
Germán Carrillo
|__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
Define it as:
export JAVA_HOME=/usr/local/bin/jdk1.6.0_06
Alex
On Sat, May 10, 2008 at 4:31 PM, Germán Carrillo
My JAVA_HOME is defined, I know because when I type "echo $JAVA_HOME", it
But when I try to run startup.sh I read this message: "The JAVA_HOME
This environment variable is needed to run this program"
Thanks in advance.
Germán Carrillo
  |\__
(:>__)(
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
