Hello all,
My setup is
openlayers + Geoserver 1.5 RC2 with 2 layers:
A geoTiff and a shapeFile
When through the opelayers GUI select the max zoom level the following error occurs
java.lang.OutOfMemoryError: Java heap space
and the Geoserver crashes!
Has anyone encounter something similar ?
Thx
×ñçóéìïðïéåßôå Yahoo!
ÂáñåèÞêáôå ôá åíï÷ëçôéêÜ ìçíý ìáôá (spam); Ôï Yahoo! Mail äéáèÝôåé ôçí êáëýôåñç äõíáôÞ ðñïóôáóßá êáôÜ ôùí åíï÷ëçôéêþí ìçíõìÜôùí
http://login.yahoo.com/config/mail?.intl=gr
gpio Oxxce ha scritto:
Hello all,
My setup is
When through the opelayers GUI select the max zoom level the following error occurs java.lang.OutOfMemoryError: Java heap space
Hmmm... may be. I guess when fully zoomed in, the single pixel
of your tiff file becomes so big that it's well wider than the screen.
In this case the rendering code OOM's in fact (just a temporary failure,
it affects only the request you're making and those so unlucky to
hit the server as the same time).
Is this your case?
ps: ah, I guess we should simply refuse to render coverages when so
zoomed in...
Hm,
probably you are right.
How I can refuse to render my raster in full zoom ?
thx
Andrea Aime aaime@anonymised.com Ýãñáøå:
Hello all,
My setup is
error occurs
Hmmm… may be. I guess when fully zoomed in, the single pixel
of your tiff file becomes so big that it’s well wider than the screen.
In this case the rendering code OOM’s in fact (just a temporary failure,
it affects only the request you’re making and those so unlucky to
Is this your case?
zoomed in…
Ciao,
which java args did you use to start the GeoServer? Could also paste here
the characteristics of the geotiff you a reusing?
Simone.
gpio Oxxce wrote:
Hello all,
My setup is
error occurs
Thx
Χρησιμοποιείτε Yahoo!
Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Java-heap-space-error-tf3427516.html#a9554840
I didnt use any special arguments , just the java command.
Could also paste here the characteristics of the geotiff you a reusing?
I used the NASA’s Blue Marble .ecw file, and then with the fwtools by issuing the command :
gdal_translate -of GTiff
i produced my tiff.
Thx
“Simone.Giannecchini” simboss1@anonymised.com Ýãñáøå:
Ciao,
Simone.
gpio Oxxce wrote:
Hello all,
My setup is
error occurs
Thx
I used the NASA's Blue Marble .ecw file, and then with the fwtools by issuing the command :
i produced my tiff.
Heh??? No, that's wrong, it would produce a file that would be bigger
than 4gb. You have to split or compress it. Plus, use -co "TILED=YES"
when creating it. You sure you did non provide any other options?
Hi Andrea, All
Heh??? No, that’s wrong, it would produce a file that would be bigger
than 4gb. You have to split or compress it. Plus, use -co “TILED=YES”
Well the size is smaller because the selected bbox is relative small. Also i reproduced my tiff with the -co “TILED=YES” option but the memory problem continues in large zoom levels.
gdal_translate -of GTiff -co “TILED=YES” -projwin 23.30 35.91 26.43 34.40 world-topo-bathy-200401-3x86400x43200.ecw my.tiff
thx
i produced my tiff.
