[Geoserver-users] java.lang.NoClassDefFoundError
Using Geoserver 1.3.0 on Sun Solaris 8 using JDK 1.5.0_06 and having all environment variables set as follows
JAVA_HOME=/usr/java
export JAVA_HOME
GEOSERVER_HOME=/export/disk024/geoserver
export GEOSERVER_HOME
GEOSERVER_DATA_DIR=/export/disk024/geoserver/conf
export GEOSERVER_DATA_DIR
...I keep obtaining stacks like:
10:54:34.637 WARN!! Error for /geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:tiger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQUEST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.02924949245278,40.70060354838641,-73.9883552568504,40.72110115289822
java.lang.NoClassDefFoundError: org/vfny/geoserver/servlets/AbstractService$ServiceStrategy at ...
or
11:26:01.037 WARN!! Error for /geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:tiger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQUEST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.0088023746516,40.70060354838641,-73.96790813904921,40.72110115289822
java.lang.NoClassDefFoundError at...
what goes wrong?
many thanks for your help, bd
It might be a Java 1.5 issue. Have you tried with java 1.4 and seen the same errors?
Brent Owens
(The Open Planning Project)
JAVA_HOME=/usr/java export JAVA_HOME GEOSERVER_HOME=/export/disk024/geoserver export GEOSERVER_HOME GEOSERVER_DATA_DIR=/export/disk024/geoserver/conf export GEOSERVER_DATA_DIR
10:54:34.637 WARN!! Error for /geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:tiger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQUEST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.02924949245278,40.70060354838641,-73.9883552568504,40.72110115289822 java.lang.NoClassDefFoundError: org/vfny/geoserver/servlets/AbstractService$ServiceStrategy at ...
or
11:26:01.037 WARN!! Error for /geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:tiger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQUEST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.0088023746516,40.70060354838641,-73.96790813904921,40.72110115289822 java.lang.NoClassDefFoundError at...
what goes wrong?
This SF.Net email is sponsored by xPML, a groundbreaking scripting language
that extends applications into web and mobile media. Attend the live webcast
and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=k&kid0944&bid$1720&dat1642
Geoserver-users mailing list
