Did you check this site:
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
Look for the jvm options in the “configure your container for production” section.
regards
Stefan
Von: Bradley McLain [mailto:bradley_mclain@anonymised.com]
Gesendet am: Dienstag, 25. November 2008 05:12
An: Geoserver-Users
Betreff: [Geoserver-users] java.lang.OutOfMemoryError: Java heap space problems when displaying multiple layersWhat I am trying to do is display several layers using openlayers and geoserver. This includes 1 Google Map layer and 2 WMS layers as outlined in attached picture. Code was modified from provided example.
However when I try this and use the map for a little while I get “java.lang.OutOfMemoryError: Java heap space” errors on both the map and in the console which is running geoserver.
I tried this in both the 1.7.0 and latest-trunk builds and the problem occurs in both.
It appears to work fine when I remove my wms layer which has a custom style applied. The other layer simply uses the polygon layer which comes with geoserver.
Custom Style
<?xml version="1.0" encoding="ISO-8859-1"?> Default Line A boring default style A sample style that just prints out a green line Rule 1 Green Line A green line with a 2 pixel width #319738 2 Variety Times New Roman Normal 16 bold #FF0000This style works fine when i just open it using the map preview page.
Any help with this would be much appreciated.
Brad
Bradley Mclain
Systems Administrator Trainee
De Bortoli Wines Pty limited
De Bortoli Rd, BILBUL NSW 2680
e: bradley_mclain@anonymised.com
