Please keep the discussion on the list, as other developers need to chime in as well.
The answer is it really depends on the functionality. Some functionality is suitable for being put into the core of geoserver. But some functionality is more suitable for being an extension. From what I have heard of what you want to do it sounds like this is more suitable as an extension. If the extension gets enough uptake from users and other developers, the community may decided that it should be core functionality.
Also, becoming a committer to a project like GeoServer takes time. We don't just hand out commit access to people. Getting commit access takes the trust of the other committers. By first developing in a community module is a good way to start earning that trust. It allows the other developers to review your code, and come to know the quality of your work.
But even after that, it takes more to get commit access to the core, outside of your module. Getting core commit access usually amounts to contributing minor patches that fix bugs. Once enough of your patches have been reviewed and accepted, and again once that trust is earned, you will be granted core commit access.
All in all for newcomers it is usually best to start developing code as an extension, if anything to become familiar with GeoServer development.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
Would adding this little thing qualify as a new feature and module? Why
can't I just bundle it with the existing code and let it ride?-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Wednesday, June 17, 2009 3:43 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] Java OGC Web Services Client SDKHi Ronak,
Justin,
Codewise, where do you guys already produce GeoRSS? I was thinking of
using Rome from java.net and its GeoRSS extensions:http://wiki.java.net/bin/view/Javawsxml/GeoRSS
http://wiki.java.net/bin/view/Javawsxml/RomeIn the wms module there is a georss output format. If you want to see it
quickly in action just ask geoserver for the following url:
http://localhost:8080/geoserver/wms/reflect?layers=topp:states&format=rs
sIt does not use the rome library, it rolls its own georss producer.
There is also the geosync community module which produces an rss feed:
http://svn.codehaus.org/geoserver/trunk/src/community/geosync/
It does use the rome library.
Do you mind if I bring in other dependencies? I don't know how the
whole
approval process works here on that...
Well the way it usually works is you request permission to create a community module. And then you are given some community space (like where geosync lives) to build your module. You are free to add the dependencies you need. Getting a community module is relatively easy, you just need to mail the list and explain your intentions, and get the approval of at least one PSC member.
After you feel your community module has matured enough that it is ready
to become a geoserver extension, it can be upgraded to an extension module. However, there are certain requirements for extensions above that of community modules, it needs documentation, a maintainer, a certain percentage of test coverage, etc...
The community module process is explained in detail here:
http://geoserver.org/display/GEOS/GSIP+22+-+Community+Modules
I would like to group the RSS code with the Catalog code or with the
rest of the RSS generation code...-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, June 16, 2009 4:18 PM
Subject: Re: [Geoserver-users] Java OGC Web Services Client SDKPatel, Ronak Avinash (US SSA) wrote:
Right but the plumbing to invoke and register the listener and then
what
kind of URL scheme do we want to use....I would imagine that's
something
the Geoserver team would want some say in...also...
You mean the url schema for the feed? Yeah I guess have a couple of options here. But I am thinking maybe something like:
http://localhost:8080/geoserver/rest/catalog.rss
Besides publishing the bounding box for coverages, which is pretty
much
what I need, do we want to expand this to features as well?
We could pretty easily i think. The GeoServer catalog model abstracts the idea of a coverage and a feature type into a "resource". Every resource has a bounding box so it would be no extra work.
I'm thinking I would also just publish the wms url of the layer out
the
GeoRSS feed so external services can just hit that url to pull the
exact
layer.
Good idea. Simply tagging the feed entry with an atom:link which
points
back to the wms call should be relatively easy as well.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, June 16, 2009 3:39 PM
Subject: Re: [Geoserver-users] Java OGC Web Services Client SDKWell.. .there is the CatalogListener interface, which can be used to listen to catalog events. However, on 1.7.x it will the tricky. The
way
things work is that when something in the catalog gets changed, everything gets updated. So tracking what changed is hard. I guess
your
listener could maintain an internal list, to see what changed on an event, but it would be a pain.
On trunk however, the events are granular, so you only get an event
for
what changed.
In both cases, once your listener knows what changed, it would be relatively easy to simply write the result to out a rss feed.
-Justin
Thanks Justin...as is usual with me I found the answer right after I
posted to the mailing list...I'm going to try to write that GeoRSS feed for changes to the
wms/wfs
catalogs so interested clients can learn of changes to the catalog
(add/remove layers and layer groups).I'm trying to determine an estimate on that now so I can determine
whether I should go down this path. Otherwise, I'll have to generatea
custom GeoRSS external to geoserver using a cron job...grrrr
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, June 16, 2009 2:37 PM
Subject: Re: [Geoserver-users] Java OGC Web Services Client SDKGeoTools has both a WFS and WMS client:
http://docs.codehaus.org/display/GEOTDOC/WMS
http://docs.codehaus.org/display/GEOTDOC/WFS+Plugin-Justin
I had a quick question where I was wondering if anyone knew of a
Java
OGC Web Services Client SDK. I figure this has been done to death
and
must exist out there.
Can anyone point me to an SDK I can use in my program to extract
layers,
features, etc. from Geoserver?
Thanks!!
Ronak Patel
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enablesunlimited
royalty-free distribution of the report engine for externally
facing
server and web deployment.
http://p.sf.net/sfu/businessobjects------------------------------------------------------------------------
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
