[Geoserver-users] Java OGC Web Services Client SDK
Justin,
I hooked this up but I noticed that the CatalogImpl class does not
generate any events when I add coveragestores, featuretypes, etc. from
the Configuration console.
Is there a reason for that? Or is that a bug?
I'm using Geoserver 1.7.5.
Ronak
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, June 16, 2009 3:39 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] Java OGC Web Services Client SDK
Well.. .there is the CatalogListener interface, which can be used to
listen to catalog events. However, on 1.7.x it will the tricky. The way
things work is that when something in the catalog gets changed,
everything gets updated. So tracking what changed is hard. I guess your
listener could maintain an internal list, to see what changed on an
event, but it would be a pain.
On trunk however, the events are granular, so you only get an event for
what changed.
In both cases, once your listener knows what changed, it would be
relatively easy to simply write the result to out a rss feed.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
Thanks Justin...as is usual with me I found the answer right after I
posted to the mailing list...
I'm going to try to write that GeoRSS feed for changes to the wms/wfs
catalogs so interested clients can learn of changes to the catalog
(add/remove layers and layer groups).
I'm trying to determine an estimate on that now so I can determine
whether I should go down this path. Otherwise, I'll have to generate a
custom GeoRSS external to geoserver using a cron job...grrrr
Sent: Tuesday, June 16, 2009 2:37 PM
GeoTools has both a WFS and WMS client:
http://docs.codehaus.org/display/GEOTDOC/WMS
http://docs.codehaus.org/display/GEOTDOC/WFS+Plugin
-Justin
I had a quick question where I was wondering if anyone knew of a Java
OGC Web Services Client SDK. I figure this has been done to death and
must exist out there.
Can anyone point me to an SDK I can use in my program to extract
layers,
features, etc. from Geoserver?
Thanks!!
Ronak Patel
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
