On Sun, Nov 22, 2015 at 5:22 AM, Raif S. Naffah <raif@anonymised.com> wrote:
> USE_STREAMING_RENDERER=true
Actually... too, the shapefile renderer is long gone,
and so is that variable... just removed it from the docs
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
